Gold standard for water proofing basement?
More specifically the connection between the concrete slab and the walls (concrete blocks). I know it would be best to have poured concrete walls but that doesn't fit us at this stage. The basement walls can be covered with water repellent products or with an EPDM sheet, still to be decided but it's the transition that I'm a bit worried about.
A draining tube is foreseen around the basement and the slab has just been poured.
Champaign and Burgundy 3.2 (1986) Ex-C4 91 Ex C4 93 A8 3.0 TDI X5 |
Evolved
Don't fear the reaper. |
It'll be legen-waitforit
This is what we did, guaranteed for thelife of your home
Basement Waterproofing Information and Estimates | Wet Basement Contractors
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Backhoe and 20 tons of crushed rock did it for me. Gold standard means water doesn't come in.
Larry |
Platinum Member
Edit: Re-read your original post. Are you saying that the walls are going to be built on the basement floor? That is not how it is done around here. We pour a footing, build the walls, then pour the slab after the walls are up. If they are building the walls on top of the floor, how are they tied together? Rebar? Can you post a picture? Last edited by dad911; 06-27-2010 at 07:56 AM.. |
Tx guys, interesting reads.
unindicted co-conspirator
+1 on the W.R. Grace products
Xypex also makes a good waterproofing for CMU also look for "Sonneborn HLM 5000", it is a trowel applied waterproofing membrane that works well
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
Decided to go with a poured concrete set-up after all.
You still have a dry joint.
water will still weep thru concrete, you need to waterproof the wall and especially the joint to the existing brick wall - +1 what Milt said
Information Junky
You either give the water some where else/preferable to go, or you build a ship hull for a basement. ...and let the house rise with the tide, so to speak.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
