Team California
speeder's Avatar
Cheap OBD2 scanner?
Guys, help me out here. I want to buy a cheap scanner for obd2 cars, doesn't any of these work on any obd2 vehicle? I thought that was the idea of v.2 over obd1. That you don't need a separate scanner for each make of car/truck.
I have a little friend with a '99 Miata that is throwing a code, (CEL), I want to help her out and figured that a scanner would be good to have anyways. I looked on eBay and most of them seem to reference one brand or another of car...WTF?
I'm green as can be on this, guidance please.
Here is a page of them, any of these look ok?
obd2 scanner items - Get great deals on Parts Accessories, obd2 items on eBay Motors!
Denis
Old 07-11-2010, 12:03 AM
Now in 993 land ...
aigel's Avatar
They should work for all models. I have an innova scanner I bought at WalMart for around $100 and it works on everything I have tested to date (a dozen different cars myself and lent out many times to friends and coworkers). I would go by walmart or the local autoparts store and get a new reader there.
George
81 SC (sold)
Old 07-11-2010, 12:28 AM
Team California
speeder's Avatar
Thanks, George. I don't actually have a Walmart close by, (that I know of), was hoping that someone could look at the one on the eBay page and tell me if any are brands they've heard of.
Denis
Old 07-11-2010, 12:35 AM
Now in 993 land ...
aigel's Avatar
Here. This is the exact make and model I have.
INNOVA 3100 CAN OBD2 AUTOMOTIVE CODE READER: eBay Motors (item 250662182373 end time Jul-11-10 15:11:57 PDT)
Good Luck!
George
81 SC (sold)
Old 07-11-2010, 12:41 AM
Now in 993 land ...
aigel's Avatar
Ok, maybe I am wrong - or not exactly right. I have the 3100 from 2001. There appears a lot of 3100 models that are newer. These all should do fine. Make sure you get the booklet with it, while you can look up codes online, it is nice to have the booklet for immediate look up.
George
81 SC (sold)
Old 07-11-2010, 12:46 AM
Rick Lee's Avatar
Originally Posted by aigel View Post
I think that's the one I have. I paid around $70 on eBay about four yrs. ago. It has paid for itself several times. Love it.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 07-11-2010, 02:32 AM
Team California
speeder's Avatar
Thanks! You guys rock...
Denis
Old 07-11-2010, 07:21 AM
Denis-
They all do the same thing, so no biggie. The codes are government mandated.
Some just give you the code and you have to look up the description of the code.
Others have a display that gives the description.
I have a couple Actrons (one OBD I, one OBD II) that display everything and do live data logs.
I bought them used on eBay with case and OBD I harnesses for $95 a couple years ago.
You can spend $2000 on a fancy scanner but unless you know how to view the data streams, etc. the codes are all you need.
E
Old 07-11-2010, 07:33 AM
Just thinking out loud
mattdavis11's Avatar
That's cheating, Denis. Save the money and figure it out. I used to play with one that could shut down injectors and log all sorts of stuff. It was a waste of time.
91 FJ80
84 Ram Charger (now gone)
Old 07-11-2010, 07:36 AM
canna change law physics
red-beard's Avatar
I bought one a while ago, and it was something like $189, but it reads, resets, and other stuff. It even will read out the electronic speed of the car, and those numbers match the GPS unit, where the speedometer guage does not. It also had extra cables for some older vehicles and OBD1 units.
I think just about any FLAPS will carry them.
James
Red-beard for President, 2020
Old 07-11-2010, 07:54 AM
Team California
speeder's Avatar
Wallmart has this one on sale, think I'm going to grab it:
Walmart.com: Equus 3100 Innova CanOBD2 Diagnostic Tool: Auto Electronics
It's the latest/greatest version of the 3100 series, MSRP is ~$190.00
Denis
Old 07-11-2010, 08:17 AM
Team California
speeder's Avatar
If you can instantly diagnose a modern car that is running and driving perfectly but has a CEL on, (and therefore will not pass an emissions test), without using a scanner, you are better at this than me.
Denis
Old 07-11-2010, 08:20 AM
For $75 why wouldn't you. That one does everything a backyard mechanic needs, and some things even a hardcore tech would like. You're set with that one. No brainer.
Old 07-11-2010, 08:21 AM
Team California
speeder's Avatar
I don't own anything at the moment that is new enough to need this tool. But like I said, I have this little friend with a Miata.
Denis
Old 07-11-2010, 08:23 AM
Rick Lee's Avatar
Worse yet, you can have no CEL on and still fail emissions because you have unreset readiness monitors and not know it. Gawd, this was a pain in the ass with my 993. And the reset procedure can almost not be done on a public road. Luckily, the reset procedure for 993's can be done with the same procedure as for BMW's, which is well documented online. But you need a stopwatch and a good 30-40 min. of empty roads and no cops around. With the scanner, you can at least see if you got it all done before going back for another smog check. I broke a lot of laws doing this for emissions in VA and AZ, but it does work.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 07-11-2010, 08:36 AM
Senior Member
Denis, get a Sunday newspaper and find the adverts for the car parts places. They are there locally for $35 on up.
Or if you want to do it right, buy a "Scantool" that plugs into your OBDII port and will give you codes, but also real time info on the car and engine all while you drive. Its a bit more, about $150 but I love mine.
Old 07-11-2010, 08:58 AM
Pre Registered
tchanson's Avatar
Denis,
I use the OBDCOM system for all our OBDII cars.
You need to load the software on a laptop, then connect the laptop to the OBD port.
Besides translating all codes into English, it also provides a menu of other very useful real time diagnostic tools. You can also clear and reset codes.
Worth every penny of $87, and I would highly recommend it.
Tim
Old 07-11-2010, 09:37 AM
Free minder
Aurel's Avatar
You can use a laptop (if you already have one) and a USB-OBDII cable connector such as the ELM327. The original costs $64:
ScanTool.net LLC - ElmScan 5 Compact Scan Tool - PC Based Scan Tools - Scan Tools - ScanTool.net
If you want to go the real cheap ba$tard route, you can even find chinese copies off e-bay for $20, but they may not work with the standard software and you will have to find a software version that works with them (the route I took)...
http://cgi.ebay.com/ebaymotors/ELM327-Diagnostic-interface-Latest-v1-3a-OBD2-CAN-v1-3-_W0QQcmdZViewItemQQhashZitem3a5c9b114aQQitemZ25066 1769546QQptZMotorsQ5fAutomotiveQ5fTools
So in short, you can get a full working OBDII setup with data logging, read codes, reset codes, dyno test, etc...for 24 bucks shipped.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 07-11-2010, 10:24 AM
Team California
speeder's Avatar
Those are *PC only* deals, right? I'd have to buy a PC laptop, all I have are Macs these days.
EDIT: I have an Intel-based Macbook. Wondering if it will then work?
Denis
Old 07-11-2010, 10:56 AM
Now in 993 land ...
aigel's Avatar
Of course you will look a lot more desirable to the Miata owner if you hook up you MAC to the car and type around on it for a while. Othwerise, I'd keep it simple with a handheld.
George
81 SC (sold)
Old 07-11-2010, 11:27 AM
