Student of the obvious
LeeH's Avatar
Wireless routers - any reason to upgrade from 802.11b?
Wireless routers - any reason to upgrade from 802.11b? Every now and then our wireless network goes down. After rebooting it's ok. I'm wondering if it's the Linksys 2.4 Ghz router that's causing the problem.
Other than the loss of connectivity (a couple times a month max), is there any compelling reason to upgrade to a newer router? We have two laptops - one Apple one Windows, a Roku and an iTouch that are on the system. Never really had any complaints about speed, or signal with our current set up.
Lee
Old 07-13-2010, 03:34 PM
Hilbilly Deluxe
emcon5's Avatar
Unless your internet connection is faster than 11 Mbit/s, no.
Tom
(Who is still running and old netgear 11b router)
82 911SC Coupe
GTI Cup #43
Old 07-13-2010, 03:42 PM
LeeH's Avatar
Tom
DL speed is 15.9 Mb/s
Lee
Old 07-13-2010, 04:27 PM
Scott R's Avatar
Routers overheat and lockup, they get worse as they get older. Some do it, some don't. Of all the routers I've worked on, or owned Linksys has been most sensitive to this. They had an entire series that lacked proper heat sinks and most of those died in the few moths of ownership.
This has been kind of going on with Linksys for years now, people do all sorts of things to try and help, like this:
WRT54G - Adding a fan - dslreports.com
To answer your other question, unless your doing a lot of traffic on the LAN (between machines on your network) you're going to be limited by your external connection as mentioned above.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-13-2010, 04:33 PM
The Unsettler
stomachmonkey's Avatar
In addition to the external pipe there is the issue of the devices connecting.
Routers will default to the speed of the slowest connected device.
So if the Apple were G and the Windows box B you're only going to see B.
"I want my two dollars"
"Brandon Won"
Old 07-13-2010, 05:00 PM
mikester's Avatar
Send a message via AIM to mikester
From 802.11b to 802.11g I could see justifying an upgrade but be sure to get all of your client wireless devices upgraded as well. If there is one 'b' client on the network the 'g' network will revert to 'b' operation as a whole because of that client.
802.11g vs b is like the difference between Ethernet and Fast Ethernet (almost). Fast Ethernet was full duplex 100mbps where as Ethernet was 10mbps HALF duplex. 802.11g is 54mbps but backwards compatible. I could go on but I you will get better performance with the g stuff than the b stuff. Plus with some newer hardware you will get away from the likes of WEP for 'security' into something that can actually be considered 'secure' with WPA2 and AES encryption.
-The Mikester
I heart Boobies
Old 07-13-2010, 05:01 PM
id10t's Avatar
Depends on what you want to do on your network. Just sharing internet connection no reason, although you can't buy a *just* B box at a bestbuy, etc. these days, For moving large files, streaming movies (audio is fine on 11mb), etc. you want faster.
Your connectivity problems may be channel related - manually set it to 1 or 11 (6 is middle and default for most, so lots of collision space if you are close to others, also portable phones, etc. The other channels overlap slightly into themselves.
Old 07-13-2010, 06:29 PM
Formerly reformed
Our two old 'b' routers were doing that for several months. Then they got to the point where they'd just crap out entirely regardless of resets. I had one tested by my IT folks after I replaced it and was told it had likely suffered a surge.
With router prices under $70, I'd go ahead and replace it with the newest protocol and end the headaches.
1968 911P (Paperweight)
Old 07-13-2010, 06:31 PM
I run 802.11N... But I stream audio all over my apartment... I don't really need that kind of bandwidth.... But I have plenty to spare...
Old 07-13-2010, 06:33 PM
canna change law physics
red-beard's Avatar
refurb Linksys "g" routers are regularly available for $25.
James
Red-beard for President, 2020
Old 07-13-2010, 07:57 PM
mikester's Avatar
To be slightly more accurate - 802.11b/g use the 2.4 Ghz spectrum and consist of 11 channels (2.4 Ghz wide) starting at 2.4ghz(ch1) ending at 2.473 (ch11). Each channel is 2.4ghz wide so in that range there are three that do not overlap. 1, 6 and 11. A great many consumer grade wireless devices come set to channel 6. If there is an auto setting, that might work better. Your best chance for a good signal is to do a simple wireless survey of your airspace. Download 'netstumbler' onto one of your wireless computers and run it for a bit to see which channels are in use. Pick the best one that is NOT in use or has the least amount of use.
-The Mikester
I heart Boobies
Old 07-13-2010, 08:06 PM
