Checked out
McLovin's Avatar
Help me fix my blender!
It's an Oster In2itive.
We tried to run it, must have been piece of ice jammed in it, it tried to start up and jammed and died instantly.
I've read up on it ,and there is apparently a fuse in it somewhere. It seems like that fuse blew.
Prob is, I don't see anything that looks like a fuse.
Take a look, is there a fuse there?
Old 08-14-2010, 02:19 PM
1980 911 SC
I see the problem. You have the 12 blade fan. You need the 14 blade fan for better cooling.
Life's a Beach
Old 08-14-2010, 02:46 PM
nostatic's Avatar
well, that and he probably pulled a head stud...
no circuit reset (either on the board or for the AC outlet)?
Old 08-14-2010, 02:59 PM
Checked out
McLovin's Avatar
That's why I need to fix this one, I don't want to get one of those modern watercooled ones, they aren't "real" Osters!
I don't see anything that looks like a circuit reset anywhere on it. There may be one, but I can't find it.
Old 08-14-2010, 03:01 PM
You do not have permissi
john70t's Avatar
(disclaimer: the following opinions shoud probably be filed in the round file).
Don't think the motor runs on 110V, so there's probably a reduction transformer in there. Black box?. Mabye it, or the fuse, is under the top board. The Mfgr or Radio Shack might be able to order it with correct specs.
If there's a bump in the wire there could be a fuseable link.
Old 08-14-2010, 03:15 PM
nostatic's Avatar
you might want to pull the board and look on the underside.
Or get a Waring
Old 08-14-2010, 03:17 PM
Senior Member
Me thinks that some of you jokers need to stick your head in a blender!
Old 08-14-2010, 03:54 PM
MBAtarga's Avatar
Are there a total of 6 shims under that fan washer?
Mark
'83 SC Targa - since 5/5/2001
Old 08-14-2010, 06:34 PM
Navin Johnson
TimT's Avatar
She really worked me over good
She was a credit to her gender
She put me through some changes, Lord
Sort of like a Waring blender
'69 911 GT-5
'75 914 GT-3
and others
Old 08-14-2010, 06:50 PM
Band.
The black box is a power relay that turns the motor on. Don't see a fuse in there. . . . .
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 08-14-2010, 08:30 PM
Used Up User
imcarthur's Avatar
Ah, some Warren . . .
There is no fuse visible. The black box is probably a relay as Gogar pointed out. Without a wiring diagram, all you can do is poke around with a voltage meter but success is doubtful . . .
Ian
'87 Carrera Cab
Old 08-14-2010, 08:33 PM
Formerly reformed
Just for the sake of asking . . . did you try a different outlet?
1968 911P (Paperweight)
Old 08-14-2010, 09:11 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
I have seen fuses that look like diodes
Have you tried the blender forum?
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 08-14-2010, 09:39 PM
9dreizig's Avatar
"Todd"
Old 08-14-2010, 09:41 PM
crustychief's Avatar
Or get a Waring
There appears to be another/secret board under the first. I would take a look there as well.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 08-14-2010, 10:15 PM
