JW Apostate
Charging problem- Help, I'm at the track!!
1999 Ford ZX2- ( I'm sorry )
Came in after a session yesterday and the water was boiling over into the overflow and the cooling fan was not running. The temp gauge was not showing hot and the tach had been acting funny, bouncing up and down from my revs and being stuck at zero. The car was very slow cranking. I had my nephew bring me a new alternator and a voltage meter. The battery was very low ( Optima Red Top ) and the old alt did nothing. I swapped in the new alt, while I charged the battery off my running F-350. The battery had 12.2 volts and started the car, but no charge and the battery started draining down. Both alternators are going back to town for testing today. Any ideas? Is there a fuse in the charging circuit I may have overlooked? Thanks. I'll be checking in all day between student sessions. I'm hoping to get it running today so I can get some laps in and run all day tomorrow. KT
'74 914-6 2.6 SS #746 '01 Boxster |
Hi
Kind of sounds like a short is causing your troubles (all that other weird stuff going on), i think the "no charge" is just a symptom.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
Check ALL grounds first. All connections of the battery cables. Look for any heated or burnt wires. Also make sure the battery is fastened down tight. Not so important with the optimas but still can cause some funky electrical gremlins.
Just throwing out ideas to you.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Petie3rd
the fords are plagued with faulty charging systems the charging system runs through the computer so it may have taken a dump, but check the grounds first and the wires connected to the grounding lugs and the power wires connected to the lug connectors. if they get loose they can cause these charging issues
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Just thinking out loud
Cooling fan is shot and drawing current.
83 944 91 FJ80 84 Ram Charger (now gone) |
JW Apostate
Any and all ideas welcome!!
Thanks KT
canna change law physics
Does it have an external voltage regulator? That could do it.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
![]() Hope it helps!
Brent Early85 944 LM6Y Paint Code |
JW Apostate
Thanks, I'll use that.
KT
JW Apostate
Word is: Both alts tested BAD.
My old one and the 'new' one. Replacement 'new' one is being tested first and delivered to the track this afternoon! I should get some laps today. Yay!! KT
JW Apostate
**UPDATE**
The auto parts stores in Reno are staffed by people that do not know how to test alternators... After they tested ALL of the replacement alts at the neighboring stores as BAD, someone got the bright idea that maybe they we're doing it wrong. Turns out, my alt is good after all, which makes my situation worse. Now I have to catch the gremlin in the engine bay. Back to square one. KT
I'm home all night if you want to trailer it here and work with some light and get a shower
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
JW Apostate
Thanks for the offer, Todd, but that's a lot of work to break down my entire pit.
I'll do my best to figure it out here today/tonight. KT
JW Apostate
Cooling fan does not come on at all.
KT
RETIRED
Ground and hot wire the fan......if it works it's in the wiring.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
JW Apostate
Turns out it was the electrical cut-off switch that was bad.
The alternator charge back circuit was off when the switch was off or on. I moved the wiring over to bypass the switch and then went out and blew the transmission... Heading home in the morning. KT
Petie3rd
lucky you didnt damage the differential or the the serpentine belt
JW Apostate
I'd like to be driving, but this will be just what I need to focus my attention on the 914 again.
KT
JW Apostate
Still had some fun. 100mph at turn in! KT
