MAGA
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Speaking of engineering and permits, what is the live load calc for the 2nd story floor?
First, thanks for all the replies.
Sorry I wasn't more clear. When I said I wanted to build a crane, it will be an indoor crane and be akin to my rotisserie. Best I can describe it will be a typical engine lift with the legs rotated 180 and some mechanism for hauling up the goods. I pictured welding a winch to the boom and a pulley at the end of the boom. Weights would sit on the legs so it doesn't topple over. Some answers to questions: It's exactly 20 feet from the ground to the base of the window, window is 37 inches from floor. A forklift could work, rental place has 20 foot lifts and just need some way to receive it. One limiting factor is any equipment on the outside of the building has to pass through an 8 foot high tunnel. Can't go up the stairs, press is too big and too heavy. Moving companies wouldn't touch it. dtw is absolutely correct, I don't have the time to make this and renting a solution is better. BUT, building this now, it would save tons of time in the future in receiving and shipping goods. I could also bring the Ducati up top. I think an early 911 shell will also fit through the windows. ![]() I'm considering something like a 1 or 2 ton electric hoist mounted onto the crane superstructure in some way. No permits, this crane does not exist.
Tru6 Restoration & Design |
Unoffended by naked girls
Partial disassembly and reassembly?
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
not really necessary but could be handy.
Pictures would help..
JR |
of what? the building?
here is the press.
How much structure have you got above? Hang a piece of Ibeam up and get an overhead hoist setup.... Make it to where the hoist can be slid along the Ibeam and the Ibeam slid in and out the window....
No. Whatever you're moving. It's the way I've gotten machines in my basement when size or weight is a problem.
got it.
the top carousel can be removed reducimg about 300 pounds BUT: it must be refitted exactly as it was before removal the control panel wiring goes through it and therefor I would have to disconnect and reconnect over 100 tiny wires that control the press there is a brass bearing that fits over the center shaft which is precision fit. Talked with the factory, very very hard to get back on once off.
that my friend was my first thought. My second thought was tearing the roof apart and everything tumbling down. I will take some pics tomorrow of the roof structure.
Shaun... Seriously get in touch with a sign guy.... They will understand what you are lifting, and should treat you a helluva lot better than a rigging co.
I'll make some calls tomorrow, thanks.
Sid's prolly got the best idea. They sometimes have to sling some ungainly signs..
AutoBahned
worst case you can build your own steel framework inside the bldg. - tie it into the bldg frame if you want - just make it strong enuff to foist your load, then hang your hoist off of that
strongly recommend that you make/buy something that can slide back & forth - not just go up & down |
it's always easy to get stuff in, think about getting it back out
78 SC all over the shop 74 911 Stock |
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
MAGA
While I am thoroughly disgusted by ever increasing governmental safety regulations, common sense and my sense of self preservation would obviously prevent me from trusting an Audi to perform such a task.
Rigging companies deliver forklifts on 'tilt-and-load' flat beds.
Truck and driver fee is usually $125/hr or so. Even with a four hour minimum.... |
