AutoBahned
RWebb's Avatar
12 pt. vs. 6 pt. sockets - Which is BETTER?
now that the mid--term elections are over (and the transmission gear lube thread seems to be winding down), I thought a rousing debate on sockets would be appropriate.
have at it...
Old 11-03-2010, 01:52 PM
Control Group
Tobra's Avatar
6 point
Old 11-03-2010, 01:53 PM
Senior Member
Superman's Avatar
6 point
Mocha 1978 911SC. "Coco"
Old 11-03-2010, 01:54 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
4 point...
Michael D. Holloway
https://5thorderindustry.com/
Old 11-03-2010, 01:56 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Two three-point.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 11-03-2010, 01:59 PM
canna change law physics
red-beard's Avatar
I like screw drivers and hammers
James
Red-beard for President, 2020
Old 11-03-2010, 02:00 PM
Paul_Heery's Avatar
6 point, they get a better grip on your nuts.
Old 11-03-2010, 02:01 PM
AutoBahned
RWebb's Avatar
I see the write in candidates are doing better than the 12 pt.s and that the 6 pt.s have quickly surged into an early lead...
What are the political advantages of the 6 pt. socket?
Old 11-03-2010, 02:02 PM
Scott R's Avatar
Depends on the job. Exhaust manifolds on a Land Rover requires a 12 point, tie rods I would use a six.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-03-2010, 02:08 PM
Split the difference and try a 9 point.
Old 11-03-2010, 02:14 PM
cbush's Avatar
Guess 12 points would be better for tight areas, but I always use 6 point when I can--much better grip/torque transfer to the nut-in my opinion.
Chuck
70 & 75 911S
96 993 C4S
'10 F-150
Old 11-03-2010, 02:25 PM
Virginia Rocks!
VaSteve's Avatar
Those spiral rusty nut extractors.
Old 11-03-2010, 02:27 PM
Vice Grips!!
Dave
1969 911T Coupe
1972 911E Targa
A930Rocket's Avatar
6 point is the way to go, but why do I have so many 12 point?
Old 11-03-2010, 02:28 PM
Zeke's Avatar
It shouldn't matter. But, if your nuts aren't in good shape, they may slip.
Old 11-03-2010, 02:33 PM
Unconstitutional Patriot
turbo6bar's Avatar
You losers stay in the 80s with your rack of sockets. Gator grips changed my life.
Old 11-03-2010, 02:41 PM
Unregistered
sammyg2's Avatar
If the bolt or nut is a standard hex, a 6 point socket will get a better grip and transfer more torque than a 12 point, especially if the head is rusted or partially stripped or whatever. The 12 point is more convenient as it can go on indexed many different ways.
Iffn the head is made for a 12 point (as in many aircraft fasteners or some header bolts) then you have to use a 12 point.
I prefer 12 point on smaller sizes, like 1/4" drive and smaller 3/8" drive.
For the larger 3/8" drive sockets and all 1/2" and 3/4" drive, 6 point is the way to go.
And all sockets that will be used on an impact gun should be 6 point, hardened, heavy duty and designed for impacts or they'll eventually crack and can cause injury.
Old 11-03-2010, 02:43 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Used a 12 points to removed a broken wheel lock nut... work like a charm
Who Will Live... Will See
Old 11-03-2010, 02:44 PM
Unregistered
sammyg2's Avatar
Those are loosers, not losers.
Or maybe they are tighters.
Either way I've been turning wrenches too long and I'm too set in my ways to go for those new-fangled gimmicks.
Old 11-03-2010, 02:45 PM
Detached Member
Hugh R's Avatar
After you've rounded off the bolt, or nut, go to Sears and get their "Bolt out" sockets (as advertised on TV by Bob Veila). They have internal biting teeth and are really good at getting rounded nuts and bolts off.
Hugh
