AutoBahned
12 pt. vs. 6 pt. sockets - Which is BETTER?
now that the mid--term elections are over (and the transmission gear lube thread seems to be winding down), I thought a rousing debate on sockets would be appropriate.
have at it... |
Control Group
6 point
She was the kindest person I ever met |
Senior Member
6 point
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Targa, Panamera Turbo
4 point...
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Unoffended by naked girls
Two three-point.
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
canna change law physics
I like screw drivers and hammers
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
6 point, they get a better grip on your nuts.
AutoBahned
I see the write in candidates are doing better than the 12 pt.s and that the 6 pt.s have quickly surged into an early lead...
What are the political advantages of the 6 pt. socket? |
Depends on the job. Exhaust manifolds on a Land Rover requires a 12 point, tie rods I would use a six.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Split the difference and try a 9 point.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Guess 12 points would be better for tight areas, but I always use 6 point when I can--much better grip/torque transfer to the nut-in my opinion.
Chuck ------- 70 & 75 911S 96 993 C4S '10 F-150 |
Virginia Rocks!
Those spiral rusty nut extractors.
Vice Grips!!
______________________________ Dave 1969 911T Coupe 1972 911E Targa |
6 point is the way to go, but why do I have so many 12 point?
It shouldn't matter. But, if your nuts aren't in good shape, they may slip.
Unconstitutional Patriot
You losers stay in the 80s with your rack of sockets. Gator grips changed my life.
Unregistered
If the bolt or nut is a standard hex, a 6 point socket will get a better grip and transfer more torque than a 12 point, especially if the head is rusted or partially stripped or whatever. The 12 point is more convenient as it can go on indexed many different ways.
Iffn the head is made for a 12 point (as in many aircraft fasteners or some header bolts) then you have to use a 12 point. I prefer 12 point on smaller sizes, like 1/4" drive and smaller 3/8" drive. For the larger 3/8" drive sockets and all 1/2" and 3/4" drive, 6 point is the way to go. And all sockets that will be used on an impact gun should be 6 point, hardened, heavy duty and designed for impacts or they'll eventually crack and can cause injury. |
83 911 Production Cab #10
Used a 12 points to removed a broken wheel lock nut... work like a charm
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Unregistered
Detached Member
After you've rounded off the bolt, or nut, go to Sears and get their "Bolt out" sockets (as advertised on TV by Bob Veila). They have internal biting teeth and are really good at getting rounded nuts and bolts off.
Hugh |
