Slackerous Maximus
HardDrive's Avatar
Qantas A380 engine failure.
Curious if the pilots and engineers have an opinion as to the cause of the failure. To the untrained eye, it doesn't look like shrapnel from a disintegrating part has pierced the engine housing. What could cause an explosion like that? Why would it happen 5 minutes after take off, as opposed to when the engines were WTFO on take off?
2014 Cayman S, PDK
Old 11-04-2010, 11:27 AM
I ain't going if it ain't a Boeing!
DD summer/winter: 2000 Boxster S
DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale)
http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story
Old 11-04-2010, 11:35 AM
Great photos here:
Notgelandeter Airbus: Trümmer auf Batam - SPIEGEL ONLINE - Nachrichten - Reise
From an AOG guy's perspective, that hole in the top of the fuel cell (the duller gray area aft of the black line) is going to be tough to fix. It's in a continuous, structural skin that very well may (depending on their design) span the entire wing. At a minimum, it spans half the wing, depending on where it might taper out on the outboard side. The hole forward of the black line is all just fiberglass or other composite leading edge panel, which is easy to replace.
There are typically 3-4 of these span-wise panels comprising the upper side of the wing center box, the main structural member of the wing that doubles as a fuel tank. The rest of the center box is made up of the lower wing panels and the front, main, and rear spars, plus any intermediate or partial spars. The piece that penetrated this upper panel had to go through either the front spar or the equivilent panel on the lower wing. In other words, at a bare minimum, it looks like possibly two major structural members of the wing have been compromised. Parts that we don't patch - we replace them. It ain't cheap to do that...
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 11-04-2010, 11:44 AM
Good thing the shrapnel didn't decide to enter the cabin...
Old 11-04-2010, 01:24 PM
nostatic's Avatar
that just begs the question: does shrapnel have free will?
Old 11-04-2010, 02:40 PM
Who makes the engines?
1972 911T/S MFI Survivor
Old 11-04-2010, 02:48 PM
Senior Advisor
James Brown's Avatar
Looks to me that the fan part of the turbofan let loose from ingestion of a bird or piece of cowling which causes other blades to fail and on and on till they shut it down. Not sure if you CAN shut a engine down on climb out like the C-5, shutting down an engine that has a fire or is malfunctioning will make the aircraft unstable leading to uncontrolled rolling. In other words, better to land and let the ground crews handle the fire than crash in a big hole and loose everything. Yeah, that wing is going to take some time to fix!!
08 Cayenne Turbo
Old 11-04-2010, 02:52 PM
MFAFF's Avatar
The Qantas A380s use RR Trent 900 engines...so do SIA...
Emirates use Engine Alliance units and Air France use GE...
So I guess that patssle will limit flying to Boeing airframes powered by PW and GE engines....
or maybe he/ she should see what happens when a American Airlines 767 had its CF6 suffer an uncontained disc failure (just out of the maintenance centre)....they have now scrapped that airframe in situ as the fire damage was too great to repair economically.
Regardless of the engine/ airframe this type of failure (it appears to be the disc not blade, the disc holds all the blades in place and a large piece was found on the ground some distance away....) is unlikely to be contained by a reasonable cowl design (it would need to be armour plating)...
RR will be burning the midnight oil on this one.. as will all the large turbofan makers...
Share with me. Teach me something I didn't know. Make me think. But don't make me a bit player in your passion play of egotism. Dueller. 13/03/09
Old 11-04-2010, 02:56 PM
Senior Member
Superman's Avatar
From it's perspective, yes.
Too bad about that AIRBUS failure. AIRBUS has had some problems lately. It's just a shame. I'm very sad.
Boeing on the other hand, is still doing what it always does. Making safe, reliable, quality aircraft. I wonder if they could make reliable tankers. In the United States of America. And I just....Hmmmmm....I just wonder if in today's economic and political environment, I wonder if it might make sense to build those military tankers right here in the United States of America.
Mocha 1978 911SC. "Coco"
Old 11-04-2010, 03:06 PM
Senior Advisor
This is a engine failure not an airframe failure. But yes I say "It's Boeing or I'm not going!"
08 Cayenne Turbo
Old 11-04-2010, 03:13 PM
Mothy's Avatar
Send a message via AIM to Mothy
Previous Qantas problem - air bottle explodes and rips out side of 747
Current Qantas problem - engine failure rips hole in wing
Both land safely with zero loss of life.
I don't care if it's Boeing or Airbus - both airframes did their job when put under stress from external unexpected sources.
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 11-04-2010, 03:24 PM
B58/732
BlueSkyJaunte's Avatar
Now let's all reflect on the wisdom of a 4-engine design (A380) vs. a 2-engine one (777).
ΜΟΛΩΝ ΛΑΒΕ
Old 11-04-2010, 03:35 PM
Evil Genius
Rusty Heap's Avatar
Too funny, "boeing verses airbus". Yeah and my American made cars alternator is made is mexico.
That's like Saying Harbor Freight Tools are just as good as Craftsman or other off-loaded goods.
Both are subcontracted out to the hilt to overseas and just rebadged.
Any guesses why the 787 is 2-3 years late being delivered and flight tested?, cheap un-trained labor making inferior quality parts behind schedule. Everything is offloaded. All to save a buck up front. Like spending $1 to save a dime. Just doesn't make sense with all the rework and poor quality. Shim to fit, that is Boeings motto.
I did 20 years at Boeing, Jeff has 30.
No offense to Higgins. He fixes the ones that breaks, but it's just a machine, and everyone once in a while things break.
Twin engines are no problem with the thrust they have these days, yes you can limp one home on a single engine.
Life is a big ocean to swim in.
Wag more, bark less.
Old 11-04-2010, 03:47 PM
Senior Member
Appears to be a bit far forward to be a fan, more like a disk.
The damage to the wing and possibly fuel tank is MUCH more bothersome. Had that caught fire there is a very good chance that the wing would have gone and the plane gone down with it.
You can shut any engine off on any modern airplane these days. It cuts the fuel, hyd, air and electrical to the engine. Yes it will stay windmilling around if possible.
Joe A
Old 11-04-2010, 03:58 PM
B58/732
I'd rather limp home on three engines than on one!!!
ΜΟΛΩΝ ΛΑΒΕ
Old 11-04-2010, 04:03 PM
Did you get the memo?
onewhippedpuppy's Avatar
It's called a rotor-burst, when something (usually ingestion) causes the compressor and/or tubine rotors to seperate from the hub. They would otherwise turn into shrapnel, so engine makers have to undergo expensive and complicated testing to prove that the engine casing will contain the blades. It would be interesting to know how this engine so completely came apart.
‘07 Mazda RX8-8
Old 11-04-2010, 05:52 PM
So, apparently, the test wasn't representative of real life?
Old 11-04-2010, 06:22 PM
carreradpt's Avatar
James, the C-5 I believe you are talking about had a TR malfunction (it deployed) on #1 during the departure that the crew was unaware of. If they had known, they could have reduced power on that motor and probably have been fine. Any uncontained engine fragging is serious shyte, but look at how many folks were on this jet. Damn.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 11-04-2010, 07:07 PM
aap1966's Avatar
Qantas emergency landing at Singapore - PPRuNe Forums
(As for) Michael Moore:Calling that lying liberal POS propaganda a documentary is like calling PARF the library of congress.
I knew it would happen, just not so soon...........
Old 11-04-2010, 07:50 PM
Senior Advisor
I only know of this (uncontrolled roll) because a buddy of mine got our crew (we were flying Navy P-3C's) into the C-5 simulator at Travis AFB. Every time they failed an engine on us, we shut it down, like the P-3 and we could not keep the aircraft flying. Those AF guys got a kick out of us trying to fly that big thing 3 engine. Finally, they told us never to shut anything down til on the runway or in a descent to landing. Piece of cake. That was eons ago. Modern aircraft today can fly on one engine just fine.
08 Cayenne Turbo
Old 11-04-2010, 09:43 PM
