slodave's Avatar
Originally Posted by trekkor View Post
So close!
KT
You're not supposed to track the trailer, just the car!
Old 11-06-2010, 09:28 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
Its all about the wheel bearing grease. Really!
Michael D. Holloway
https://5thorderindustry.com/
Old 11-06-2010, 09:37 PM
RETIRED
Joe Bob's Avatar
As I mentioned in post #23.
2012 ML350 3.0 Turbo Diesel
Old 11-06-2010, 09:42 PM
Lots of trailers run close to or exceed their weight rating. Fail.
Trailers are left outside and tire walls deteriorate. Fail.
Trailers hit curbs and other obstacles that the tow vehicle misses. Fail.
Trailers get low maintenance, bearings heat up, run low pressure. Fail.
Trailers get the tail end boogie, low pressure tires, wall failure. Fail.
No where do you mention wheel bearing grease. So you get a FAIL!
Michael D. Holloway
Old 11-06-2010, 09:49 PM
RETIRED
Joe Bob's Avatar
OK, Lubie.....what maintenance is there on bearings? Ya lube them every time ya go out, zirc fittings, bearing buddies, etc.....old crappy lube heats up, heat transfers to the wheel, to the tires. Tires overheat and fail by cord seperation or sidewall blow out....
Trek can be dim but he ain't stoopid.....
Old 11-06-2010, 10:07 PM
JW Apostate
trekkor's Avatar
Thanks, Mikey!
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 11-06-2010, 11:10 PM
Gon fix it with me hammer
svandamme's Avatar
it probably looked like a cheap ratty tire when it was new. Seriously.
Where else but on trailers do you still see tires with such thread?
The manufacturers don't need to uphold the same standards as on regular vehicles, they assume that must trailers have more then one axle and as the tires are redundant... add the low diameter and there you go...
I never understood this.. . people put the weight of an entire car, + the trailer chassis on 4 tiny wheels with cheap tires... Yet buy fancy expensive tires for the car that is put on top of the trailer...
The cheap tire has to take more weight then the expensive tire... yet people are surprised when they blow out....
Stijn Vandamme
BIMDIESELBMW116D2019
Old 11-07-2010, 03:17 AM
