Wayah Road Warrior
Shadetree930's Avatar
Edumacate me about Torque Wrenches
If I am going to be a shade tree mechanic, I've got to have a torque wrench right?
If I am only going to buy one, what should it be?
02 996tt White
87 930 GP White (Sold)
87 911 Targa Guards Red(Sold)
Old 11-09-2010, 10:09 AM
It depends on what you are working on. I suspect you will really want more than one. One for the lower range and one for higher ranges.
I had to buy a new one to get to the higher ranges recently for my rear suspension work.
Old 11-09-2010, 10:14 AM
Bill is Dead.
cashflyer's Avatar
Buy the best. http://www.torqwrench.com
I prefer a Split-beam Click Wrench.....
Split-Beam Click Wrenches overcome many of the problems associated with micrometer-style wrenches in abusive environments. The wrench has few components, and all critical parts are welded together at assembly. There is no need to "work in" a C series torque wrench before using it the first time. Nor is it necessary to adjust to the lowest torque setting after use. Setting the tool requires only fingertip force since the adjustment mechanism is not under load.
Old 11-09-2010, 10:24 AM
myamoto1's Avatar
Whichever one you end up with, BE SURE TO RESET IT TO ZERO (0) after each use.
Josh
85 M491 Coupe - "Fat Bastard"
Old 11-09-2010, 10:39 AM
Southern Class & Sass
Dixie's Avatar
I have the split beam wrench shown in the link. I would not advise buying it. While the wrench is probably accurate, the dial to set the torque lacks granularity. It's akin to having a sniper rifle without any sights...
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 11-09-2010, 11:54 AM
Bill is Dead.
cashflyer's Avatar
Josh - As mentioned above, you do not have to reset a split beam type.
Rob - I have a few of the Precision Instruments split beam type torque wrenches. My 1/2" drive, which has a range of 50-250 lbft, is adjustable in 2.5lb increments. That's only 1% of total capacity, and I haven't encountered any tech documents that call for greater precision at that torque. But your needs may be different. If you need more precision, I suggest the dial type torque wrenches. They also have greater accuracy.
Some other considerations:
Choose the right torque wrench for the job. A torque wrench has a sweet spot - an area in the range where the device is most accurate. Usually, it is around the middle of the range. So if you want to torque to 100lbft, don't choose a TW that has a capacity of 20-100. Choose one that has a capacity of 50-150 (or similar).
The higher the capacity, usually the worse the scale resolution.
For example, my 800nm Snap On dial TW reads in 20nm increments. That means that I could be off by as much as 10nm on any given reading.
Finally, DRO torque wrenches exist for those who cannot properly read a scale, or who want the ease and convenience of reading numbers directly.
Old 11-09-2010, 11:56 AM
i use a $20 Harbor Freight for my 911 wheel nuts
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-09-2010, 02:25 PM
A930Rocket's Avatar
Snap-On. Nuf said.
Old 11-09-2010, 07:29 PM
Bill Douglas's Avatar
I only use a torque wrench once every 3 or 4 years so I didn't want one that needed calibrating every yearr or two. And I didn't want to pay too much for something I almost never use. So I bought one of those bendy ones. An engineer said they use a bendy one to calibrate the fancy ones.
Old 11-09-2010, 07:45 PM
Porschedr.'s Avatar
Snap On TechAngle.
The best.
Old 11-09-2010, 07:59 PM
Almost Banned Once
sc_rufctr's Avatar
These are mine... All I'll ever need (except the rear axle nut on a 911)
Go with quality and you won't regret it.
- Peter
Old 11-09-2010, 08:05 PM
We have several different ones in the shop including a snapon with about 6ft of handle. I consistently grab for the armstrong though. The size is right, it adjusts properly, and I've never had problems with it not getting the torque right. I want to say dad picked it up for around $70.
Old 11-09-2010, 09:10 PM
Now in 993 land ...
aigel's Avatar
Not a craftsman. They work well, but their handles / locks always break. No lifetime warranty on those.
G
81 SC (sold)
Old 11-09-2010, 09:17 PM
Bill is Dead.
cashflyer's Avatar
For what it's worth, Precision Instruments has been making Snap On torque wrenches since 1938. Snap On also gets some of it's torque wrenches from their subsidiary, CDI Torque Products.
Old 11-10-2010, 04:55 AM
enzo1's Avatar
thanks for the info!
76' 911s Signature Edition
Old 11-10-2010, 08:02 AM
Monza_dh's Avatar
interesting viewpoint here:
Keeping It All Together, Part 3
$35 and a six pack to my name.....
'88 Diamond Blue Carrera CE 3.4-SOLD
Old 11-10-2010, 01:28 PM
myamoto1's Avatar
I saw that, but I'm a creature of habit and would zero it just because it'd bother me if it wasn't at zero. That's what happens when you probably have ADD and OCD at the same time
Josh
Old 11-10-2010, 02:09 PM
Zeke's Avatar
G
That did happen to me. I did the repair and recalibrated it. I will buy another better brand if I ever do anther motor. In the meantime HF is good enough for lug nuts and my beam plus the fixed up Craftsman will get me by fixing lawnmowers.
Old 11-10-2010, 03:04 PM
