AutoBahned
thx - it is about halfway downloaded
do I unzip it to the HDD on my working computer (Win XP) first ?l |
Yes, unzip to a directory....
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
AutoBahned
got it - am downloading the ImgBurn pgm now - Roxio did not work
it's burning now BTW - I found a patch subdir on my HDD and it seemed like I needed to patch your ISO image to use English? Last edited by RWebb; 12-27-2010 at 11:02 PM.. |
No... Just need to burn the ISO. Patch stuff can be ignored.
AutoBahned
IMgBrn is having problems on the verify
guess I'll continue on Wed. thx again |
Go crazy and turn the verify off.
AutoBahned
it found 2000 errors in sector so & so
I'll boot off of that CD tomorrow... |
Hmm. Never seen that before. The image is good. If it works, boot to the CD, it will give an option to boot the utilities (I'm leaving the name out purposely) or boot to the HD. Boot the utilities. Option 1 should be partition tools. There are a number of HD partitioning tools there. I booted a slightly later version, but I think they are the same. First choice should work....
I can PM my number and you can call tomorrow if you'd like.. Dave
AutoBahned
sure - let me know the best time to call you also
I am booting that 1st selection off the menu tree you outlined right now - but it seems to be taking a long time to load a driver... |
Something's not right. It should not take very long. I'd almost suggest booting the cd in a working pc, go through the same initial steps and see if it loads faster. Just don't do anything once it's loaded on the good pc or you may have other problems.
canna change law physics
Is the SATA interface setup as SATA or ATI in the BIOS for the DVD drive? If you're not going to run any ATI equipment, set the BIOS setting to SATA only.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
AutoBahned
ok, I'll set SATA Combined Mode to Disabled instead of the default. I can't see how that will make a difference...
still waiting to see if it can install -- it says "Setup is starting" is it even normal for the thing to take 1+ hours to install Windows? or has it been 2 hours... Last edited by RWebb; 12-28-2010 at 05:27 PM.. |
AutoBahned
I got nowhere with WD tech support for the HDD. BTW, their Email support cannot communicate with their telephone support!
AutoBahned
Not for a fast system
AutoBahned
WD told me to re-seat the RAM modules - seems odd since they passed several memory tests, but I'll do that when I get home (at downtown office now) and then try again.
I'll give it more than the 4 hours last night, James... I'll also try another, slower speed burn to make the Magic ISO CD. After those attempts, I guess my question would be whether I should return the drive to WD under warranty or to newegg for an exchange. |
I reloaded Win 7 on a fresh disk on this machine in about 30 minutes. It certainly sounds like the disc is hosed.
You might want to consider getting a cheap harddisk for data and a 64GB SSD drive for startup. I'm doing this right now and it works great.
AutoBahned
yes, that thought occurred to me...
AutoBahned
the only menu choice that looks like it will do anything is an operation to format the partition; type is set to NTFS & "selected partition is identified as (BAD) - you cannot change that last item. there is also a big red X that will delete the partiton - I figure what the hell, why not... |
AutoBahned
when you try to Apply those operations, it can't do it...
Advanced has an option (only one not grayed out I think) to set that partition to Active. it seemed to do that but put up an info box that says Setting partition active: (BADMBR, primary volume, etc." MBR makes me think it stands for Master Boot Record, so... that doesn't sound good; nor does the continual attempt by this program to use the term BAD. it wants to reboot, so... |
