LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
AutoBahned
RWebb's Avatar
Problem with new Computer & Win 7 Setup
Problem on a custom built system where I had already installed Windows 7 (and it seemed to work fine for a few days). I was trying to install a new driver for an hp monitor and somehow it crashed, and I now cannot install (re-install Win 7).
I can boot Win 7 from the install CD (System Builder) but w/o that in drive D:\ the system will not boot. If I DO boot from the install CD, then installation of Win 7 cannot continue - I get an error msg that Windows cannot be installed to that disk. If I try to create a new partition, that fails also.
With Win 7 System Builder CD in drive D:
Goes past BIOS screen…
“Windows is Loading files” – black screen; then “Starting Windows”; then Language & Preferences Screen
if I Select “Install Now” (instead of Repair option)
- “Setup is Starting…” – on Blue screen with plant and white traces graphic; 35 minute wait
- License Acceptance Page
- Type of Installation – Upgrade or Custom (advanced); chose Custom
- Where do you want to install Windows: used to show 1 partition; now shows 2: Disk 0 Partition 1 : System Reserved 100 MB total; & Disk 0 Partition 2 931 GB – busy for 17 minutes
- “Windows cannot be installed to this disk; Disk 0 Partition 2” – Details: Hardware may not support booting to this disk. Check that disk’s controller is enabled in BIOS menu”
- had to Cancel Windows Installation as could not proceed
if I Select Repair Windows – Startup repair could not repair this computer
- cannot test system memory
- can go to Command Prompt – shows a drive “X:\”??; cannot access drive C:\ there
if I Select Repair Your Computer:
shows System Recovery Options, Use recovery tools.. Select an Op Sys (but none is listed)
- I get a chance to load drivers, but have no idea what filenames they might be on the Windows System Builder CD
With Motherboard Drivers CD in drive D:
Just a blank screen if I let it go past the BIOS
if I hit Del to Enter BIOS Setup:
to >SATA Configuration choice shows “SATA 1 Device : Hard Disk” & “SATA 2 Device : ATAPI CDROM”
Boot: identifies HDD first drive as “SATA:3M-WDC WD1002”
if I hit to Enter Bio-unLOCKing:
brings up Windows Boot Manager screen
says OS is Win 7
F8 to reach Adv. Options – unexpected I/O error & refers to Winload.exe
Turn On and let it run past the BIOS with no CD in D:
Goes past BIOS interrupt screen & then displays a blinking underline cursor in upper LH corner of screen, then screen goes blank
I have switched SATA cables and used a different socket on the motherboard, which did not help:
- With Win 7 System Builder CD in drive D:
same as above, then - Where do you want to install Windows: shows: Disk 0 Partition 1 : System Reserved 100 MB total; & Disk 0 Partition 2 931 GB
- told it to format Partition 2, but that failed
- back to the “Partition menu screen” and told it to Delete Partition 2… “failed to delete the selected partition”
- that's where I'm at now & it is starting to get frustrating...
Old 12-27-2010, 04:30 PM
Scott R's Avatar
Does the motherboard vendor have a driver for disk controller? On the "advanced" items menu during the disk prep you can add one via usb drive, floppy, etc. But I doubt that's it.
Likely something happened to the drive and windows attempted to repair it, but failed and left you with a corrupted drive. (I'm guessing this is the case since you mentioned that the controller and partition numbers are wrong)
Also could just be a bad bootloader pointing to the wrong partition. Rather that write that all out, here is someone that did:
Recovering the Vista Bootloader from the DVD - NeoSmart Technologies Wiki
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-27-2010, 05:18 PM
Information Junky
island911's Avatar
Geez, webb, all of those answers are on the net. ...so, I'll just let you find the answers.
Old 12-27-2010, 05:21 PM
Bad memory?
1987 Carrera
Old 12-27-2010, 05:22 PM
AutoBahned
RWebb's Avatar
Win 7 has the drivers built in to the OS (or so sez WD (Western Digital, the HDD manf.) on it's FAQ.
"you mentioned that the controller and partition numbers are wrong"
- I did?? I don't know that they are wrong. Did something I posted mean they were wrong?
Memory tests fine.
WD tech support Emailed me and told me to run a diagnostic pgm - the catch 22 is you appernetly have to get Windows booted to run the diagnostic pgm...
Old 12-27-2010, 05:23 PM
canna change law physics
red-beard's Avatar
Do you have access to another machine where you can hookup the disk?
James
Red-beard for President, 2020
Old 12-27-2010, 05:31 PM
Scott R's Avatar
Memory tests fine.
I took this as the expected partition was 1 and was now showing 2:
Also it's not the drivers for the hard drive, it's the drivers for the controller. That driver would be provided by the mainboard vendor or the chipset manufacturer. For instance, Nvidia in some caes, or LSI logic.
Edit:
And yes, do as Redbeard mentioned and hook that drive up to a host machine and get your data off.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-27-2010, 05:33 PM
I would wipe the drive using Dariks Nuke and Boot. I never trust a repaired corrupted install. Reinstall and update all drivers - especially the video driver. Bad video drivers cause many issues.
Old 12-27-2010, 05:39 PM
red-beard's Avatar
Windows 7 has built in SATA drivers. The MB drivers may be better. It sounds like the Win 7 install needs to needs to be re-done. I would format that drive first, to see if there are some bad sectors.
One the install before fail...
1) Drivers for a monitor? Usually a monitor wouldn't have drivers.
2) The drivers are usually specific to x32 and x64. It is possible you installed the wrong one.
James
Old 12-27-2010, 05:42 PM
Scott R's Avatar
Windows 7 has drivers for hard disk controllers that were available to Microsoft at the time that Windows 7 was compiled, unless he's slipped newer drivers in. And a lot of monitors have drivers, Sony for instance has them for most of their LCD's.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-27-2010, 05:50 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Sounds more like a BIOS setting issue where the OS install package doesnt recognize the boot options. Sometimes in the BIOS settings there's factory default settings that Windows has issues with, they usually need to be very generic. If this is a custom build, I'd bet something's been changed.
Google is your friend in these cases.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 12-27-2010, 06:13 PM
AutoBahned
RWebb's Avatar
- I don't think I have any SATA machines available.
If I can somehow get to a "DOS prompt" on this one, I could try running their diagnostic pgm that way...
Old 12-27-2010, 06:49 PM
AutoBahned
RWebb's Avatar
Originally Posted by Scott R View Post
... it's not the drivers for the hard drive, it's the drivers for the controller. That driver would be provided by the mainboard vendor or the chipset manufacturer. For instance, Nvidia in some caes, or LSI logic.
Edit:
well, shouldn't that driver be built into the ROM?
IF not, how can I find it?
I do have an option on the "where do you want to install Windows" screen to Load Drivers. I could put the CD from the Motherboard in and load the controller driver if I knew what its name was.
There is no data on the HDD - see OP. No way to test drive out of the computer - see above post.
Old 12-27-2010, 06:52 PM
AutoBahned
RWebb's Avatar
The BIOS setting are all in their default state - I did that several times.
The drive will not format nor can the partition be deleted.
did I miss any questions above?
I have not slipped newer drivers in, but perhaps somehow a program did that.
re 32 vs 64bit drivers, I have not seen anything on any screen about that as a choice - I am just following the install directions... making the choices outlined above - and I have made every choice you can on the whole install decision tree.
Now, one question: should the machine be able to do something with the motherboard CD in drive D: first? i.e. before I put the Windows System Builder CD in?
IS there anything I can do by interrupting the BIOS via the Del key?
Old 12-27-2010, 06:59 PM
Scott R's Avatar
The motherboard CD contains the drivers for the various components on the board, audio, video, etc. It may be bootable, and may have some sort of diag program or installation helper application however that's normally reserved for the larger manufactures.
Windows in this case cannot correctly access the hard drive in it's current state. The BIOS on the machine is likely correct since windows knows about the drive and it's geometry. The BIOS settings that may be suspect would be the boot order. The HDD needs to be in the boot order somewhere.
Recover the data on the drive using an external enclosure or another host computer, and then re-install as suggested above. That would be the path of least resistance right now.
If the drive is physically bad then windows will probably not install even on a cleaned drive. If the problem is software then a clean install will correct that.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-27-2010, 08:26 PM
AutoBahned
RWebb's Avatar
- this happens over & over again
It will NOT Boot off of the motherboard CD.
The HDD has always been needs to be in the boot order of the BIOS. I've tried changing it from first to having the CD-ROM drive first, no change in results.
Old 12-27-2010, 09:25 PM
AutoBahned
RWebb's Avatar
I went back to the OP and used bold and underline to ID better the various decision trees or choices I've been working thru for the last few days...
Old 12-27-2010, 09:28 PM
slodave's Avatar
Randy, I'm going to PM you a link to a magic ISO. Download it and burn the ISO to a cd. Are you familiar with ISO images?
Once the cd is created, throw it into the problem optical drive and boot to it. It has a number of tools for getting yourself into trouble. I have to boot it on a local pc to refresh my memory on the menu choices, but it will take a bit to get the image from my server anyway.
We'll kill the partitions and you should be able to reformat with ease at that point.
Dave
Old 12-27-2010, 09:47 PM
AutoBahned
RWebb's Avatar
thanks much!
no, not familiar, but am about to Goggle that term...
ok now I know a little about those...
any special steps to write the image to a CD?
can I just use software that would typically be included when I bought a Dell 8300 about 7 or 8 years ago - Roxio CD Creator is one of them....
Old 12-27-2010, 10:18 PM
slodave's Avatar
There are a bunch of free burners out there, if you don't have Roxio or Nero...
Here's one I found.. Looks like it may be user friendly
The Official ImgBurn Website
Old 12-27-2010, 10:25 PM
