rnln's Avatar
why water goes upward?
Have you guys seen this?
Fat butt 911, 1987
Old 02-19-2011, 11:19 PM
cool optical illusion.
Old 02-19-2011, 11:41 PM
rnln's Avatar
looking at it the second time, there are only 2 towers. How he make us see the zic zac????????
Fat butt 911, 1987
Old 02-20-2011, 12:00 AM
slodave's Avatar
This theory seems to work.
Possible Explanation for Escher Waterfall Machine | Geekosystem
Old 02-20-2011, 12:08 AM
rnln's Avatar
seem like a lot of work for this short video
Fat butt 911, 1987
Old 02-20-2011, 12:22 AM
Free minder
Aurel's Avatar
I think the first segment goes downwards, which gives the water enough kinetic energy to "climb" the remaining segments. The way he fills the waters in also seems to matter, as it creates a wave effect.
But the more a look at this thing, the less I understand how it is built. There is some wicked optical illusion designed in there, so who knows how it really works...
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 02-20-2011, 04:11 AM
The first three legs are sitting on the floor and running either flat or slightly down hill. If you compare the height of the base where the wheel is to the side wall height of the legs it does not change. There are steps cut in the side walls to look as though it is stepping down. The last leg that makes a left looks to run slightly up hill. You can see the change behind the left pillar of the right tower. You can actyually see the water pool at this point before it continues to move. The legs of the water fall are not actually attached to the toers. The towers are strategically placed to look like the legs are attached and are running up hill. But in reality the towers do nothing. Try and remove the towers with your minds eye and you can see it. So the weight of the water falling out of the pitcher and eventually from the water wheel is enough to push the water slightly up hill on the last leg.
I should also add the last leg where the water pools is turning back on it's self. Not a 45 deg. angle but probably much sarper inorder to get the end over the water wheel.
Old 02-20-2011, 06:28 AM
ckissick's Avatar
The water is clearly falling some distance to hit the water wheel. How do you explain that? Also, it appears to be a perpetual motion machine.
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 02-20-2011, 07:09 AM
Unregistered
sammyg2's Avatar
Oh those pesky physics. Water does not flow uphill.
Unless it's hooked up to a gererator.
Old 02-20-2011, 10:30 AM
jeffgrant's Avatar
The joys of forced perspective.
This explains it fairly well, taken from another site.
Take a close look at the reflections in the water on the floor for clues.
Old 02-20-2011, 12:24 PM
Danimal16's Avatar
Illusion? Maybe. But remember Water always flows down gradient which means that it can flow up hill.
Dan
Old 02-20-2011, 01:25 PM
slodave's Avatar
The video was edited. You can see at least one cut, shadows are funny and how the water never flows into one corner.
Old 02-20-2011, 01:59 PM
Hendog's Avatar
It's an illusion, no doubt. Regardless of the method, it is well executed in my opinion. I've enjoyed it.
Well done!
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 02-20-2011, 03:53 PM
jeffgrant's Avatar
Agreed... it reminds me of the Penn and Teller bit where they do the 3 Cups trick with clear cups, showing you how it's done.
Even watching it with everything shown to you, it's still amazing.
Old 02-20-2011, 03:57 PM
You do not have permissi
john70t's Avatar
I watched the video before and was trying to figure it out, but then the commercial streaming-video format stopped this.
I could not get the streaming-video in the thread to pause and/or exit. How did these speakers get so loud? Stop. Stop. Do not want.
Old 02-20-2011, 10:56 PM
i watched the video before and was trying to figure it out, but then the commercial streaming-video format stopped this.
+1000
Old 02-21-2011, 05:38 AM
Unregistered
sammyg2's Avatar
What is even more puzzling is why some people feel the need to try to believe what it obviously not true.
Call it the bigfoot or ufo syndrome for lack of better terms, they NEED to believe in the unbelievable.
Doan know why exactly.
Old 02-21-2011, 07:56 AM
wdfifteen's Avatar
This is pretty cool. He could be a better showman though. Why stage this is a crappy garage?
Ever wonder why people "check" their video cameras by standing in front of it and looking into the lens?
Old 02-21-2011, 09:29 AM
Virginia Rocks!
VaSteve's Avatar
It's more believable this way.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 02-21-2011, 09:54 AM
RPKESQ's Avatar
Hey!
No religion bashing here. Move it to PARF.
Who Dares, Wins!
Old 02-21-2011, 03:22 PM
