Parrothead member
Men, power tools and the stupid things we do with them.
My radial arm saw is probably one the most heavily used tools I own. Been using it for 20 something uneventful yrs. Tonight I was cutting some stock. After I finished i lowered the blade to make a different cut. I had multiple pieces to make the same cut.
Why I did this I'll never know. As I was putting the wood up against the fence, I hit the power switch which is on the arm. The blade which i had lowered to far ( and not checked) was against the table. It spun up, shot forward towards me and just skinned my wrist. a 1/4 inch over, and it might have taken my hand off! In all my years I have never, ever turned it on without having my hand on the slide assembly. Real dumb azz move! Scared the crap out of me!
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." Last edited by VINMAN; 03-12-2011 at 10:16 PM.. |
How about this one
![]() Only way to get the routes I needed in the control cavity of my LP... The "Min" is for the factory recommended minimum insertion - to be safe. ![]() ![]()
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Vin,
How did the blade come off. the shaft turned the nut off and the blade went flying? |
Dave, that should be all right if you are not taking too big a cut. I have done that many times. Why not just a longer bit?
Parrothead member
It didnt come off. The whole slide assembly moved. The blade was down, touching the table.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
![]() You could feel the change in vibrations with the router. EDIT: That bit was damaged towards the tip early on in the project from the brass collar that's on the base plate. That made it really out of balance at full length.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD Last edited by slodave; 03-12-2011 at 10:33 PM.. |
If you want to consider a vacuum cleaner a power tool, I heard of a guy that was using it to clean-up around a gas tank and you can figure out the rest.....it sucked the fumes from around the tank and exploded.
A good friend of mine owns a fire restoration shop and he told me of a story where a guy was using a buffer on his garage floor and was using gas to remove the stubborn stains.......luckily for him the fire damage was isolated to the garage with minimal smoke/water damage to the house.
2015 GLK (Momma's ride) 2016 F-250 2001 BMW M5 65 CSX 427 Roadster |
Almost Banned Once
- Peter |
That's an achievement!
Almost Banned Once
- Peter |
Safety and accidents is why they don't make radial arms saws anymore. Only make table saws where the blade doesn't move.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
I expected this to be a "VASH" thread.
![]() While drilling a hole for something, I got smacked in the face when the bit stuck and I wasn't paying attention. The drill kept going around and my face was in the way. Luckily, no one saw it.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Information Overloader
My question is how many times did it hit before you moved the obstruction? I was cutting an overhead limb off a tree and had plenty of time to tell my self, "This is gonna really hurt." And it did.
Just once but that was enough.
Huh? They still make them.
1986 3.2 Carrera |
ffrctr,
Done that, too. I was lucky & using a ground fault extension cord.
drew1 wife has 924 turbo |
Un-Registered User
I've got way too many to list.
I was using a cordless drill with a 1/4" bit to drill a hole in my firewall. I decided to elongate the hole by pulling up on the drill. Well, the bit broke about 1/2 way down and the broken bit, still in the drill, still spinning, whacked me right in the side of the face. That one took a while to stop bleeding. As for the radial arm saws... This has been around for many years now. I sent mine to them. Radial Arm Saw Recall
Don 1988 Targa |
I have cut firewood with a circular saw. I still have all 10 fingers too!
No left turn un stoned |
I've been working wood for more than 40 years....both as a pro and as a hobby.
When I first came into the trade most of the oldtimers were missing a digit or 2.....but some weren't.....that makes an impression on a young fella. IMO, you have to be just a little afraid of these tools and not get into the "familiarity breeds contempt" mode. You take one look at a radial arm saw or a shaper (a big router) and say to your self: "that thing could eat me up", but in fact, they all can. I've had more close calls on a drill press & table saw than any others....maybe because they don't scare me enough. The discipline to think "what can possibly go wrong" is a digit saver.....yes, I'm now an "old timer" and I have all mine, albeit with some scars. A certain amount of luck is involved.
JPIII Early Boxster |
Did you get the memo?
It only takes once, that's why my carpenter father in law is missing two fingers. He was cutting a piece of siding with a chop saw and was distracted by his customer asking him a question, ouch.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
