DanielDudley's Avatar
I have a dimmer for my ceiling fan lights. They last a long time, but are hardly ever at 100%.
Old 03-15-2011, 05:15 PM
Zeke's Avatar
Appliance lamps like you buy for the oven. Last forever. Not decorative though. Decorative lamps are not heavy duty.
canna change law physics
red-beard's Avatar
Excellent suggestion!
James
Red-beard for President, 2020
Old 03-15-2011, 06:16 PM
Information Junky
island911's Avatar
in the 'fwiw' category... the Appliance lamps (or higher voltage rated bulbs) use much more electricity for a given light output. --that's the trade-off for not having to mess with it as often.
Old 03-16-2011, 08:42 AM
Zeke's Avatar
Another trick is to put the switched light circuit on a dimmer. The lamps will last even longer at lower voltage.
I like this one:
If you can't see it, there is a common toggle with the slide right next to it.
Old 03-16-2011, 05:50 PM
KarlCarrera's Avatar
I know it would be a hassle, and perhaps not relevant, but I always start with the simple things.
Check all connections. Power, neutral and ground, all should be separate. Do you experience any difficulties with anything else on this circuit?
A loose, floating, or open neutral connection may cause some difficulties. Is this a recent problem or has it developed over time?
Just some thoughts.
Karl
88 Targa
Sorry, I didn't check #20
Old 03-16-2011, 06:33 PM
