AutoBahned
RWebb's Avatar
MS Word 2003 Problem
In Windows 7, I keep getting an error saying that Autorecovery "has been postponed" apparently forever as I lost a bunch of work recently. Word 03 is not very stable on my Win 7 computer.
I deleted normal.dot and rebuilt the new one Word created by using the Organizer to pull my much needed ah.. 'stuff' over into the new one.
BUT -- it still happens.
Not finding any usable info with Google searches.
Any help?
Old 03-22-2011, 01:06 PM
Hi
Targa Me's Avatar
I'm using Word 03 with Windows 7 getting the same errors.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 03-22-2011, 02:06 PM
canna change law physics
red-beard's Avatar
I'm using 2003 with no issues
James
Red-beard for President, 2020
Old 03-22-2011, 08:50 PM
Burn the fire.
Brando's Avatar
32 or 64 bit?
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 03-22-2011, 10:05 PM
AutoBahned
RWebb's Avatar
My Win 7 install runs 64 bit, but Word 2003 installs in the x86 pgm dir - I assume it is 32 bit (?)
Old 03-22-2011, 10:10 PM
Where is that wrench?
EdT82SC's Avatar
Try OpenOffice? It seems to work well with Word documents up to office 2003. Not so well with the newer zipped xml file format (.docx).
Ed T.
1982 911SC
Porsche Wallpaper
Old 03-22-2011, 10:57 PM
red-beard's Avatar
I'm running Office 2003 on various comuters, 4 of them Win 7 Pro 64 bit and 1 Win 7 Pro 32 bit.
James
Old 03-23-2011, 04:03 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Openoffice.org. Live worry free forever more.
Old 03-23-2011, 05:27 AM
red-beard's Avatar
If Open Orifice had an integrated e-mail, on the order of Outlook, I'd consider it. Thunderbird falls down in that respect.
James
Old 03-23-2011, 05:45 AM
Eric Coffey's Avatar
If your Win7 came with the pre-loaded trial of Office 2010, you might try uninstalling it (and Office 03), then re-install 03.
Old 03-23-2011, 11:42 AM
red-beard's Avatar
He made the PC himself. It came pre-loaded with NADA.
James
Old 03-23-2011, 11:50 AM
AutoBahned
RWebb's Avatar
this may help others:
Corrupted normal.dot. Rename it or delete it, and see if the problem is fixed. Location can be found in:
Tools - Options - File Locations - User templates. -- done
Close Word and do a system cleanup using Ccleaner to remove all temp files. -- done
Could be a misfiring add-in. Remove add-ins one at a time to see if the problem goes
away. -- no add-ins ??
Turn off the Word AutoRecovery feature by going to Tools, Options and then the Save tab and unchecking the box that says Save AutoRecover info every:. Then Next you can try to delete the Normal.dot file with Word closed. When you open Word again it will create a new Normal.dot file. You can do a search of your hard drive for the file but make sure you have the Show hidden files and folders option checked in your folder options. - done
Make sure the document is set to 2003 format by going to Tools, Options and then the Compatability tab.
There are problems with saving changes to settings and to Normal.dot that have been reported:
Word does not save changes or you receive an error message in an Office program after you install Adobe Acrobat 7.0
Take a look here for additional information, including information on editing the registry:
How to troubleshoot problems that occur when you start or use Word 2010, Word 2007, Word 2003, or Word 2002
Risky:
Corrupted registry entry, usually the Data key; rename or delete the Data key, which can be found here:
HKEY_CURRENT_USER\Software\Microsoft\Office\11.0\W ord
If nothing seems to work then you can try a repair installation of Word. Go to Add/Remove Programs and click on Word or Microsoft Office if you use the Office suite and then use the repair option to have Word repair any corrupt files. Or you can uninstall Word and then reinstall. I would suggest running Ccleaner after the uninstall before reinstalling.
Old 03-28-2011, 03:14 PM
