1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Another question for experienced mechanics
This is a pic of the thermostat housing on my Dodge 4.7. Does this look like a failure in the casting or is this just poor machine work?
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 04-01-2011, 09:50 AM
Scott R's Avatar
Common problem, timing cover is disintegrating. You will likely find rust in the radiator and heater core with this issue. Coupled with a mysterious overheating issue that you can't seem to fix.
You need the cover, gaskets, pump and radiator flush with an entire cooling system flush. Not a fun project given where that cover is.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-01-2011, 10:43 AM
1.367m later
KevinP73's Avatar
Research supports your reply. The dealer wants $367.00 my cost for the cover. e-bay has some from Allstar Automotive in Denver for $35.00-$70.00 but not being able to inspect it in person makes me a little leary to buy used.
Old 04-01-2011, 11:01 AM
