Irritating. Netgear. Router
Moved into the new place, had some internet issues on and off since then.
Last night, kid comes downstairs and says his laptop won't connect to the router. Wireless.
Netgear WNR3500 Rangemax.
I try my laptop. No dice.
Lady says no dice on hers either.
Wierd. We were just watching Netflix via the Xbox and wireless connection an hour earlier...
I get connected early this morning, briefly.
I work at it for half the day. New firmware. Lotsa reboots, unplugs, reset button, etc... Nothing. Then the wired connection won't even work.
I even set it to unsecured.
Trying to get connected, I keep getting told the security key is wrong. Nope, it's correct. I change it several times, set up a new wireless name, etc... round and round.
Only two years old.
Laptop eventually connected to the router, but did not have any internet access.
I figure it's borked. I head out, pick up another router, come home to find the kid connected via his school-supplied Macintrash.
Check my laptop. Sure as sh.t it connects just fine.
What the....??
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 04-05-2011, 10:10 PM
The mac fixed it....
Old 04-05-2011, 10:31 PM
D idn't E arn I t
RANDY P's Avatar
check the firmware on the router. Had all kinds of issues with that Netgear myself. 2 years is about as long as it's supposed to live anyhow.
rjp
AOC/Hogg 2028
Old 04-05-2011, 10:47 PM
slodave's Avatar
Hmm. Mine must be a fluke. 8+ years a still 99%. It does choke once in a while and I have to unplug it from the wall. Not really worth buying a new one yet. It also sits about 3' from my micro.
Old 04-05-2011, 11:09 PM
rjp
I did upgrade the firmware after several failed attempts at getting it to work.
BTW, my old Linksys lasted about eight years, and it was only replaced because it couldn't throw a good strong signal all through the house I just moved out of. Stupid plaster walls...
Old 04-05-2011, 11:38 PM
canna change law physics
red-beard's Avatar
I've ended up putting multiple access points around the house so that there is a strong signal everywhere.
James
Red-beard for President, 2020
Old 04-06-2011, 06:00 AM
1966 - 912 - SOLD
lane912's Avatar
try replacing the firmwear with DD-WRT
third party open sorce firmwear for routes-
i was too tired to be pretty last night!
Old 04-06-2011, 06:26 AM
Senior Member
If you tried to connect with the hard wire and no luck then the problem may not be with the router or WiFi portion.
Old 04-06-2011, 07:06 AM
Scott R's Avatar
This would be what I would do as well, but I would have to ask, "Did you remove the router from the picture entirely and connect directly to the ISP's modem?"
If the above test worked, get rid of the router. Many of these home routers are very sensitive to heat and that's normally why you hear about them dying often. People modify the cases with fans and move them to basements to try and help that.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-06-2011, 07:23 AM
Senior Member
Superman's Avatar
I've been having trouble setting up my Netgear router. I pushed the pin to reboot it. It goes through a process where it determines the type of connection I have, then when it tries to test connectivity, it reports there is no connectivity. At that point, everything has to be rebooted including the modem. After rebooting, the modem works fine again......until the Netgear thing goes through it's process again, then everything needs rebooting again.
Mocha 1978 911SC. "Coco"
Old 04-06-2011, 09:11 AM
AutoBahned
RWebb's Avatar
are these on CAT 5/6? or are they working like WiFi relays?
Old 04-06-2011, 02:01 PM
D idn't E arn I t
RANDY P's Avatar
I've had 2 netgear G routers neither lasted longer than 2 years.
Just bought a Cisco N draft and it rocks good.
rjp
AOC/Hogg 2028
Old 04-06-2011, 02:28 PM
red-beard's Avatar
Hardwired. My house was built fully wired with CAT6
James
Old 04-06-2011, 03:57 PM
