RETIRED
More computer help....DVD player is dead.
I have a Toshiba, (TSST corp) T633A player and CD burner. Pulling up the device manager gets this error message...
The unit is non functional after a reload of the opertaing system. Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available. Downloading drivers from Dell is no help. Anyone have a suggestion? This is the last non functioning component on the Laptop....was able to fix everything else.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Burn the fire.
Replace the drive.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Are there any other devices in Device Manager that show as "disabled?" or show up with a "!" on them? A DVD drive is a child device and relies on a parent to connect it. While the drive could be dead, it could also just have a parent driver that's not installed.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
RETIRED
I've disabled and enabled it.....it was working fine prior to the O/S reload. I also lost the program for playing DVDs. It was Media Direct which was always buggy with VLC.
I've used VLC before. Decent program. Anyways, there is an exclamation mark in yellow showing that it is corrupted. My shotgun attempt that worked with my Bluetooth didn't work here. Auto searching for a solution doesn't work. A Google looking for other postings on how to get a corrupted drive working again is no good. I CAN run discs for uploading software....but not DVD/movies.
You can try this:
Step 1: Start Registry Editor type "regedit" in the Start Run box. Step 2: Delete the UpperFilters registry entry 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the details pane of Registry Editor, on the right side, click UpperFilters. Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. * If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6. * If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry." 6. On the Edit menu, click Delete. 7. Click Yes when you receive the following message: Are you sure you want to delete this value? The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry 1. In the details pane of Registry Editor, on the right side, click LowerFilters. Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only. If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site. 2. On the Edit menu, click Delete. 3. Click Yes when you receive the following message: Are you sure you want to delete this value? The LowerFilters registry entry is removed. 4. Exit Registry Editor. Step 4: Restart your computer Do so at your own risk. though I have done this many times and in certain cases it does work.
19 years and 17k posts...
My DVD burner in my 3 year old Dell Inspiron 530 died last weekend and I replaced it for $40. Easy fix...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Though, if it's a corrupt low level driver, a new drive ain't going to fix it. Nice to have extra parts to test with.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Did you mean Toshiba?
The Toshiba drive is a laptop drive. You can find them in Dell's.
RETIRED
The DVD player is now up and running. I know that people like to run Microsoft down......but while futzing with the SLODave data, MS called and dragged me along the path and fixed it. Zero dollar tech help is a nice thing.
Now...the biometric fingerprint reader is the last screwed up piece of hardware.
Unregistered
You can still use it as a cupholder .........
RETIRED
It would be a small cup, the finger port is about as big as yer winky.....
Unregistered
RETIRED
Yeah....but last time I saw it, you said it was swollen.....
