RETIRED
Joe Bob's Avatar
More computer help....DVD player is dead.
I have a Toshiba, (TSST corp) T633A player and CD burner. Pulling up the device manager gets this error message...
The unit is non functional after a reload of the opertaing system. Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
Downloading drivers from Dell is no help.
Anyone have a suggestion? This is the last non functioning component on the Laptop....was able to fix everything else.
2012 ML350 3.0 Turbo Diesel
Old 04-06-2011, 11:02 AM
Burn the fire.
Brando's Avatar
Replace the drive.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 04-06-2011, 11:15 AM
Scott R's Avatar
Are there any other devices in Device Manager that show as "disabled?" or show up with a "!" on them? A DVD drive is a child device and relies on a parent to connect it. While the drive could be dead, it could also just have a parent driver that's not installed.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
RETIRED
Joe Bob's Avatar
I've disabled and enabled it.....it was working fine prior to the O/S reload. I also lost the program for playing DVDs. It was Media Direct which was always buggy with VLC.
I've used VLC before. Decent program.
Anyways, there is an exclamation mark in yellow showing that it is corrupted.
My shotgun attempt that worked with my Bluetooth didn't work here. Auto searching for a solution doesn't work. A Google looking for other postings on how to get a corrupted drive working again is no good.
I CAN run discs for uploading software....but not DVD/movies.
Old 04-06-2011, 11:21 AM
slodave's Avatar
You can try this:
Step 1: Start Registry Editor
type "regedit" in the Start Run box.
Step 2: Delete the UpperFilters registry entry
1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the details pane of Registry Editor, on the right side, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
* If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
* If you do not see the UpperFilters registry entry, you still might have to remove the
LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
6. On the Edit menu, click Delete.
7. Click Yes when you receive the following message:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed.
1. In the details pane of Registry Editor, on the right side, click LowerFilters.
Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
2. On the Edit menu, click Delete.
3. Click Yes when you receive the following message:
The LowerFilters registry entry is removed.
4. Exit Registry Editor.
Step 4: Restart your computer
Do so at your own risk. though I have done this many times and in certain cases it does work.
Old 04-06-2011, 05:21 PM
19 years and 17k posts...
azasadny's Avatar
My DVD burner in my 3 year old Dell Inspiron 530 died last weekend and I replaced it for $40. Easy fix...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 04-06-2011, 05:40 PM
slodave's Avatar
Though, if it's a corrupt low level driver, a new drive ain't going to fix it. Nice to have extra parts to test with.
Old 04-06-2011, 05:59 PM
I have a Toshiba...
Did you mean Toshiba?
Old 04-06-2011, 06:31 PM
slodave's Avatar
The Toshiba drive is a laptop drive. You can find them in Dell's.
Old 04-06-2011, 06:32 PM
RETIRED
Joe Bob's Avatar
The DVD player is now up and running. I know that people like to run Microsoft down......but while futzing with the SLODave data, MS called and dragged me along the path and fixed it. Zero dollar tech help is a nice thing.
Now...the biometric fingerprint reader is the last screwed up piece of hardware.
Old 04-07-2011, 01:23 PM
Unregistered
sammyg2's Avatar
You can still use it as a cupholder .........
Old 04-07-2011, 02:16 PM
RETIRED
Joe Bob's Avatar
It would be a small cup, the finger port is about as big as yer winky.....
Old 04-07-2011, 02:20 PM
Unregistered
sammyg2's Avatar
That small?
Old 04-07-2011, 07:02 PM
RETIRED
Joe Bob's Avatar
Yeah....but last time I saw it, you said it was swollen.....
Old 04-07-2011, 07:28 PM
