I doubt it in hot conditions. After you turn the engine off, the fan isn't moving anymore and the engine temp rises quite a bit really fast. I questioned my dad about the practice of cooling down the engine (turbo) in his plane. I mentioned about the sudden rise after engine shutdown. It does spike. A lot of his engine is logged and can be reviewed on a computer later.
Now does a bag of ice on the intercooler of turbo cars really work? |
when I first got the car, for several months, I opened the lid when I got home to see and hear the engine runs before I come in :D
If you have been on the boost, then the IC will be hot. The ice will make a bag of water, but that's it. No engine cooling at all. Best to let it run a few minutes instead.
I often check the oil level after I get home. The car will be parked in the same spot on a level garage floor. When I shut it off I close the lid. If it cools down in 2 hours instead of 4 what difference does it really make? At the autocross the engine never gets that hot to make a difference.
If its really hot out or I've been running it hard I'll let the engine idle for 30 seconds in the garage. After it is shut off I'll pop the hood.
Did ya notice the engine lid has a big rectangular opening on it?? I guess Porsche engineers did that for cooling purposes. When I want to cool down my house, I do not feel the need to open the screen door either ;).
I did raise the lid...under the "can't hurt-might help" theory...I do the same to my now H20 cooled cars...to keep wax melting heat off the hood...
I figure it is easier on the rubber if you pop the hood, especially if you just got done getting it really hot
Are you talking about your car or your sex life? :)
:DA930
| All times are GMT -8. The time now is 09:34 AM. |
