-   -   Open Engine Lid (http://forums.pelicanparts.com/off-topic-discussions/616844-open-engine-lid.html)
shadowjack1 06-30-2011 01:29 PM
Open Engine Lid
This is something that I have been doing since I got my first Porsche, (1972). When ever I get home, pull the Porsche in the garage, I lift the engine lid. I figure that letting the heat out will keep everything "happy". I leave the garage door open and sometimes put a fan on the engine itself. Am I the only one or are others like me out there?
126coupe 06-30-2011 01:47 PM
My neighbor leaves the hood open on his Camaro when he comes home from work.
Frankly I don't get it:confused:
daepp 06-30-2011 01:48 PM
I see lots of guys doing that at the track. Couldn't hurt.
vash 06-30-2011 01:51 PM
that's stupid..everyone knows hot air drops.. (read this in green text..please)
stomachmonkey 06-30-2011 02:05 PM
I drive mine like I stole it and put it away wet.
KNS 06-30-2011 02:42 PM
On a hot day or after a long drive I'll pop the lid.
dhrcr911s 06-30-2011 02:47 PM
Track - Yes
Around town - Rarely
yetibone 06-30-2011 03:31 PM
Sometimes I do that with my 928 to heat the garage a little in the wintertime. Makes an evening smoke less uncomfortable.
Brando 06-30-2011 03:33 PM
Originally Posted by stomachmonkey (Post 6109972)
i drive mine like i stole it and put it away wet.
word!!!
ODDJOB UNO 06-30-2011 03:51 PM
i'd used to drive mine like i stole it.....................then i would open the hood and look for LEAKS! and COUNT THEM!..................and SIGH!
now after the rebuild behind us.........................all i care about is getting 700 miles on it ASAP, so i can adjust the valves and ge-dumpen der oil.
red-beard 06-30-2011 03:58 PM
I have a photo of 5 or 6 oveheated aircooled Porsches after waiting in line to re-cross the border.
http://forums.pelicanparts.com/uploa...1062431700.jpg
slodave 06-30-2011 04:05 PM
In the spring/summer months at AX, yes lid comes up as internal temps get up there.
Sometimes after a long drive during the hottest parts of summer.
azasadny 06-30-2011 05:34 PM
I used to do that in the summer, on especially hot days after a spirited drive. I would always check the engine over and be sure nothing was broken, etc... and let the heat escape. I noticed that it cooled down quite a bit after I swapped out the CIS for Webers.
cgarr 06-30-2011 06:02 PM
Yea all you guys are going to have cracked engines from cooling too fast...
legion 06-30-2011 06:14 PM
My 951 had an electric water pump. It would continue to circulate coolant after shutting off the engine, so I didn't worry...
id10t 06-30-2011 07:04 PM
Apparently the thing to do while driving across hot desert in your 356 was to put a oil can to prop the engine lid open a tad...
A930Rocket 06-30-2011 07:43 PM
At the track, I did it after every run. At home, I just drove easy for 5-10 minutes for the turbo to cool down.
trekkor 06-30-2011 07:52 PM
914's have a mesh engine lid and mine has no engine compartment tin.
I open it to work on it ( after every run ) :(
KT
island911 06-30-2011 08:51 PM
So then I shouldn't dump a five gallon bucket O water on it? :confused: yes, gti
crustychief 07-01-2011 12:00 AM
I open my decklid (no fan though) when I drive on really hot days ( 100 plus ) is it like shock cooling in an airplane? I didn't even think about that!
