Electrical gurus
I am converting a medical rehab device to my portable AC for the upcoming west coast trip in my 356. It has a small cooler with a motor in the bottom ice water is circulated through a pad that went on the afflicted surgery area. The controller is cold to coldest.
The power converter at the wall takes power down 13.9v at .9 amps. There are 4 wires coming out of it. Red, black, white, and yellow. All these meet at a Y with the 2 wires coming from the controller. I really don't want to tear apart the Y. Which wires do I splice to make the pump run continuously?
I'm running the water to an old oil cooler off my motorcycle with a fan blowing through the coils. It works great but warms up to much between cycles when the pump is not running.
Any good answers appreciated.
63 356 So Called Outlaw
76 930
Old 07-05-2011, 12:44 PM
do u have a multimeter to test the wires?
12V convention is black=ground, red=12v, although it's not uncommon to see yellow=12v either. w/o a wiring diagram, your only test is to use a multimeter to figure out what's connected to what.
Old 07-05-2011, 02:06 PM
It was so obvious. Bypassed the entire controller power converter. Went with a cig lighter plug in. I had been using a converter to go dc to ac. The pump was 12v anyway.
Going out on a 100 degree day with the windows rolled up in a black 356. Will soon know the results.
76 930
Old 07-05-2011, 02:13 PM
id10t's Avatar
Les - not the same but here in Fl the 356 isn't bad IF you have all the windows open. Mine also had a dealer installed AC unit (Artic Kar) and I still have the vent hoses up front. Get a nice breeze thru them at speed. At lower speeds, I rotate the front windows all the way around so ti forces air onto me.
Old 07-05-2011, 02:56 PM
I just back from a 30 minute test with the windows up 100+ outside. The blower I am using is a squirrel cage and it is aimed directly at the cooler. I need to build a shroud behind it to disperse the air more evenly. As it is the fan/cooler is in a 12x12 styrafoam box. I made it that way to be able to move it around the cab to try and find the best cooling options.
Old 07-05-2011, 04:11 PM
