Cajundaddy's Avatar
Mystic is right and you are back in the game. If you can set up the receiver for "quad sound" you can use the surround speaker output to power your sub and run it through a passive xover to give you just the bottom.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 07-13-2013, 12:01 PM
motion's Avatar
Not sure I'm following...
'95 993 C4 Cabriolet
Bunch of motorcycles
Old 07-13-2013, 12:09 PM
Cajundaddy's Avatar
The receiver has different program modes and one may be "4 spkr disco" "quad music" or some other description. This sends the same stereo music to your main speaker outputs and the surround speaker outputs. Connect main spkrs to main outputs, sub to surround outputs with 120hz low pass xover to eliminate full range music to your sub.
Amp surround spkr out > xover > sub
Amp main spkr out > main ceiling spkrs.
Done.
Old 07-13-2013, 12:17 PM
motion's Avatar
Thanks.
But
Arghhhhhh!
How come this stuff isn't all wireless/digital/bluetooth these days?
So, I connected the 2 subs directly to the receiver's surround outputs, with the filters inline. I didn't connect the main speakers yet. I get nothing. I tried all the various modes on the receiver, but there's no output to the surround channels.
Old 07-13-2013, 12:45 PM
Cajundaddy's Avatar
Thanks.
But
Arghhhhhh!
Owners manual for the receiver. On both my Yamaha receivers I can send the stereo signal to the surrounds. Yours should as well. Homework!
Old 07-13-2013, 01:01 PM
motion's Avatar
I know, RTFM...
I messed with the small/large settings for the surround channel and I am now getting some output into the subs, but the volume is very low, even with the volume cranked all the way up. Its barely anything. I messed with all the settings, so I'm confident I tried everything. I can't find a quad mode in the receiver, so guessing that's my problem? But shouldn't standard surround mode send something to the surround channel? Are the filters I have installed inline to the subs mucking things up?
Old 07-13-2013, 01:24 PM
Cajundaddy's Avatar
I know, RTFM...
Standard surround will only send 5.1 surround channel signal (movie sound effects) There must be a way to route the 2ch stereo signal to surround spkr out. Dig deeper.
Old 07-13-2013, 01:30 PM
motion's Avatar
Dude, I totally owe you a beer or two!
Here is the manual: http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-520_OperatingInstructions0302.pdf
Old 07-13-2013, 01:39 PM
Cajundaddy's Avatar
Pg 35 "Panorama" setting should do it. Fingers crossed.
Old 07-13-2013, 01:44 PM
motion's Avatar
Nope! Guess I should throw in the towel and plug in a powered sub?!
Old 07-13-2013, 01:52 PM
Cajundaddy's Avatar
I think there is a way to do this with your existing setup. Test your surround out by connecting the full range speakers in panorama mode. If you get sound then the amp is right and the sub wiring connections are wrong. Process of elimination. If it were mine, I would connect front FR spkrs to main, rear to surround, and a powered sub to sub out. That is best practice to dial in so many speakers to your room.
Try just the FR spkrs alone. They are good down to 50hz and the lowest note on a bass guitar is 41 hz. That is pretty good "garage quality" sound. There are lots of LF sound effects that go below 50hz but not much music is down there. Do you really need a sub?
Old 07-13-2013, 02:01 PM
motion's Avatar
Thanks, really appreciate it, but I am giving up. I've been crawling around in the rafters on 2x4s all day and not enjoying it. At this point, I just start throwing money at things ))
Now the receiver won't play anything but the tuner, so gotta figure out how to reset all the damage I did, and hookup a powered sub. I have a 12" Energy that I can use.
Old 07-13-2013, 02:37 PM
I've got a similar unit in my garage and I think you have to have speakers hooked up to the mains in order to get anything out of it, including the surrounds.
Scott
'78 SC mit Sportomatic - Sold
Old 07-13-2013, 02:45 PM
motion's Avatar
I tried hooking up the main speakers, but it made no difference. I guess the surround output will only work in Dolby mode with an appropriately encoded source.
Old 07-13-2013, 05:01 PM
Rob Channell's Avatar
Just another option off the top of my head but you could just buy some power for your existing sub with something like this:
Dayton Audio SPA250 250 Watt Subwoofer Amplifier 300-803
Rob Channell
One Way Motorsports
1979 911SC mostly stock
1972 911T Targa now with a good 2.7
1990 Miata (cheap 'n easy)
1993 C1500 Silverado (parts getter)
Old 07-13-2013, 07:26 PM
Cajundaddy's Avatar
Pg 38
Setup your speakers as front and surround "Large". Run surround spk out > LPF> Sub. Select "No" Sub for the receiver sub out and xover settings as these are only for a powered sub.
This should work.
Old 07-13-2013, 11:01 PM
motion's Avatar
I'm following, except for this part. LPF?
Old 07-14-2013, 06:54 AM
Cajundaddy's Avatar
Run speaker wires from surround spkr out to a passive 100w low pass filter or sub xover, then to your sub. Run your system in panorama mode so all speakers are receiving signal from stereo L or R.
Old 07-14-2013, 08:37 AM
motion's Avatar
Tried that, but no go. Seems this receiver just can't output to the surround channels equally.
Old 07-14-2013, 09:30 AM
Cajundaddy's Avatar
I suspect something is still missing. From the manual it appears that surround channels are equal to main channels and can be fed a stereo music signal. Where is the missing puzzle piece? The alternative is back to running a powered sub.
Old 07-14-2013, 11:08 AM
