Best process question
What is the best(quickest) way to assemble something with multiple steps of equal effort/time?
a) Complete all required steps for one unit at a time. or b) complete one step at a time for all units |
The Unsettler
How many units and how many individual steps per unit, how complicated, how many parts?
If just a few I don't think it matters. If 10 or more then I would build at least one or two completing all required steps just to make sure I understood all the steps then I'd go to completing one step at a time for the balance. You want to avoid a misstep that makes you have to backtrack on multiple units.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Turgid Member
I believe it's a generally accepted practice to complete an entire unit before moving on to the next one. This prevents you from applying the same mistake to multiple units and then having a bunch of completed, yet incorrect, units. No matter how careful you are, there's always room for errors and the hope is that if you begin making an error as you complete units, you'll catch it in time and not trash your entire assembly run.
'87 Carrera "Man who go through airport turnstile sideways going to Bangkok" |
Bill is Dead.
You'll need to take it up with the shop steward.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
"farking Porsche hero"
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" |
Dog-faced pony soldier
Subcontract it and add 5% markup.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Completing one step at a time for all units would also require you to have all of your inventory there at the beginning (not practical or cost effective) where completing the entire units one step at a time allows "just in time" inventory management and continuous process improvement. Sorry, had to through in two buzz words.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
A factor to consider is how long it takes to prepare for each step. If it takes a while to get the tools, get in position, put tools away, clean up, etc. for each step you might be better off getting set up, doing all of that step, clean up, put tools away, etc, and then moving on to the next step.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Addtionally, by assembling multiple units at a time, one can introduce concurrent operations to the mix, with careful coordination of the entire process. This should allow a quicker completion of the total number of units being built, provided there is sufficient workforce to support concurrent processing. Geez - I think my MBA studies are finally starting to pay off! ![]() -Z-man.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
