mower help - blades not spinning
Need some mower help.....
Blades aren't spinning. Belt isn't broken and w/ engine off and blades engaged it tightens up ... Nothing jammed in the deck, blades rotate by hand ... Ideas? Help a mechanical idiot out ...
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Fast Acting, Long Lasting
Bad deck clutch, maybe.
Eighteen ways to burn fuel. |
sheared pin in the engine pulley.....
1986 3.2 Carrera |
Could be a sheared key in the blade carrier. the shaft the blade attaches to has a keyway and if you have hit something hard with the blade the key can shear.
Dog-faced pony soldier
Shear pin. Yep.
RETIRED
Shear pin is a safety device.....keeps the motor from grenading when the blade hits and immoveable object.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
