Please Help: my sunroof does not work
Could you please give me some ideas on how to diagnose a sunroof's problem? I just replaced with new cables, cleaned the rails and new seals but when I turned on the switch, no movement, no sound
![]() I also replaced with a new fuse but no luck. How do I check the motor? Any other ideas? Please help. Thanks Tom
Sounds like this should be in the "911 Tech" section (assuming it's a 911). You will probably get some answers here, but the tech section would probably be a better spot for it.
How about the switch? Are you getting power at the switch, the motor, the fuse? Is there a relay?
post your ??? here if its a 911 Porsche 911 Technical Forum - Pelican Parts Technical BBS
76' 911s Signature Edition |
thanks Steve and enzo1.
I checked and replaced the fuse. I will post my question as you recommended. |
