Cayman S engine failures anyone?
Came across this today. Food for thought in that it was a car I thought would be a nice modern day 911 substitute. Over reaction or real concern?
Super Piston Slap: Cause It
Old 08-11-2011, 05:39 PM
Control Group
Tobra's Avatar
Wow, glad I bought the Mazdaspeed instead of a Boxter, really glad.
That little Mazda seems to be sort of hard on the rear tires though, I guess it might just be that it is my first turbo car and it is sort of fun to drive it looking ahead out the driver's side window.
Old 08-11-2011, 07:49 PM
Now in 993 land ...
aigel's Avatar
I am scared of all those engines. And nobody has been able to convince me otherwise.
George
81 SC (sold)
Old 08-11-2011, 07:56 PM
pwd72s's Avatar
There is a guy on the Bullitt board who suffered three engine failures in two Boxsters. He left the P-car fold...
I wonder how many Caymans will end up donated to a full auto shoot at local gun clubs?
The failure rates posted in the article are pretty frightening...
Too bad, because they really are a good looking car. But good looks only goes so far.
Old 08-11-2011, 08:05 PM
Max Sluiter
Flieger's Avatar
Well, they mean cheap, good handling chassis for racers who can put a motor in it with the fixes for the biggest issues, or a new DFI engine.
Old 08-11-2011, 09:42 PM
Sadly its not just Caymans. 997s have an apparently common problem with the failure of the #6 Cylinder Bore. Have a look at this;
997 engine failure – fact or myth? | Total 911
Old 08-11-2011, 09:52 PM
Student of the obvious
LeeH's Avatar
Dang! I had plans to pick up a Caymen once they depreciated into the mid-teens. Guess in a couple of years the trends will be more clear. Sigh...
Lee
Old 08-11-2011, 10:01 PM
Jeff Alton's Avatar
The power of the internet......
Love my Caymans S and my 996 which both get flogged on the track...... and the Cayman is daily driven. Guess I better buy a spare motor to reduce downtime....
One guy with three engine failures, wow, and I thougth I had heard it all already
www.turn3autosport.com
Old 08-11-2011, 10:21 PM
Certified User
billjam's Avatar
Wow, that's amazing! Glad I can't afford a 997
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 08-11-2011, 10:22 PM
don911's Avatar
Disappointing. A cayman S or ideally the Cayman R is on my wish list. Guess I can't beat my old 3.2 that runs all day long at the track and never stumbles.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 08-11-2011, 10:25 PM
a.k.a. G-man
Geronimo '74's Avatar
If he keeps on reasoning and deducting I'm sure he'll find that for every Cayman that was sold, two broke down....
Old 08-11-2011, 10:30 PM
Now in 993 land ...
aigel's Avatar
The air cooled engines weren't trouble free either. But the difference may be that the air cooled engines were a little easier to fix - buy a new cylinder and piston and you are on your way. And the main issues were slowly developing like valve guides not grenade type failures. You can drive the car for quite a while with a little smoke before you set aside time and $ to fix valve guides. Is that the same for intermediate shaft issues? I know the aftermarket will start picking up on these cars and some fixes are already available. It will be some time for things to shake out price and parts wise - that's why I wouldn't jump into any waterpumper (GT3 and TT excluded) right now.
George
81 SC (sold)
Old 08-11-2011, 10:46 PM
Dottore's Avatar
Yes.
And in other news, bungee jumping can cure constipation.
_____________________
These are my principles. If you don't like them, I have others.—Groucho Marx
Old 08-11-2011, 10:57 PM
artplumber's Avatar
Interesting reading on lnengineering website (fixes for the IMS issue). They rec more freq oil changes, higher ZDDP content, and note that failures are mostly in "babied" cars - less likely to fail in track driven cars. They rec keeping rpms over 2500.
Peter
'79 930, Odyssey kid carrier, Prius sacrificial lamb
Missing 997.1 GT3 RS
nil carborundum illegitimi
Old 08-11-2011, 11:03 PM
artplumber's Avatar
Maybe this should get moved to tech board - 997 or 986?
Peter
Old 08-11-2011, 11:05 PM
Control Group
Tobra's Avatar
I can see how running low rpms hurts you in the AC cars, wonder what is up with these. Wait a bit until it gets shook out I guess. When the Carrera came out with the chain tensioners, it sort of solved that issue. Maybe the thing to do would be to get a sweet running Boxster S and fix the IMS thing
Old 08-12-2011, 12:28 AM
Paper Member
My Boxster has 173 thousand miles on it now, original engine. I must have gotten lucky...
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 08-12-2011, 04:52 AM
Senior Member
I hope they continue to pick up some bad press - just means I can get a Cayman sooner rather than later at an even cheaper price with fewer miles
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 08-12-2011, 06:09 AM
s_wilwerding's Avatar
The pre-2009 Caymans did have some issues (IMS, etc.), though most can be cured. I frequent a lot of Boxster/Cayman boards, and I have not seen much talk about piston issues, so my guess it that that is getting overblown. The IMS can be fixed with an aftermarket upgrade (which I did to my 3.4). If you take some steps, you can make older Caymans pretty reliable (as many have pointed out, I'm not sure there are a lot of car brands out there that NEVER have issues).
As for post-2009 Caymans with DFI (and no IMS), the only issues I've heard of so far are some reports of high pressure fuel pump issues, which are not catastrophic and pretty easy to fix. I have yet to hear of one of the new engines failing catastrophically - keep in mind that the Cayman, Boxster, 911, Turbo, GT3, etc. are all variants of the same engine, so they were built pretty robustly.
As for the general theme of this thread, keep in mind that it only takes one dissatisfied owner to make a big stink and blow the problem out of proportion - you don't hear from the thousands and thousands of owners who have no issues.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 08-12-2011, 06:36 AM
This was posted on the Austin PCA web site last week....
I'm just looking for some collective intelligence from the Porsche community.
> I just had an complete engine failure in my 2006 Cayman S. At 52,000 miles.
I'll forgo all the drama and all for now, but I am trying to figure out my
options.
> It appears I'm missing a cam seal on one end, causing some oil loss (but not
catastrophic amounts) and the engine is dead on either one cylinder (Porsche of
Austin, leak down test) or three cylinders (TPWS, ran it briefly on their lift).
Porsche found a smashed plug in the #1 cylinder. Both are suggesting that I
replace the motor entirely, at a cost over $15k. I'm thinking that $15k buys an
awful lot of tools, parts, and beer, and I'm seriously considering having a go
at rebuilding the motor.
> My question is, is this something I can do? I've had a few people volunteer
access to a lift (though sadly, not near my house) and I'm pretty handy with
doing my own maintenance work, though I have never tried to do anything like
rebuilding an engine -- I've previously torn my Miata completely apart and back
together with the exception of going no further into the engine than a timing
belt and water pump. Luckily, I have the assistance of people who have rebuilt
motors, though not a Porsche motor.
> I've looked at the engine removal process at Planet-9, and I think with some
help, a lift, and a shop manual (which I have yet to procure), I could get the
engine out. At that point, there's a lot of assessment of where to go from
there, but I figure I can't really make things worse by tearing into the motor
since it's currently being deemed scrap. If I can rebuild it, I will. If I
need to buy a replacement used engine, I'll do that. I'm just trying to limit
the damage to my pocketbook.
> Does this sound reasonable to the rest of you guys? Do you have any wisdom to
impart before I go tearing into the motor? Anyone got a shop manual I can
borrow?
Old 08-12-2011, 06:43 AM
