LakeCleElum's Avatar
Very simple DIY project. Once the cover is off, it's just 2 or 3 minutes. Test output voltage 1st.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 12-17-2011, 07:31 AM
Detached Member
Hugh R's Avatar
$69.99 and I'm up and running. Thanks guys!
Hugh
Old 12-20-2011, 05:02 PM
Senior Member
Power Supply....I'd pull the hard drive and copy it to save your data.....but that's just me.
Same here, had it happen a couple of times...
Old 12-20-2011, 05:08 PM
GWN7's Avatar
So what was it?
I voted power supply too.
Bunch of old cars
Old 12-20-2011, 05:11 PM
Detached Member
Hugh R's Avatar
Power supply. Surprisingly, the puter seems to run quieter as well.
Hugh
Old 12-20-2011, 05:51 PM
syncroid's Avatar
Good for you Hugh. You got luckier then I. When my power supply died, it took out my mobo.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 12-20-2011, 05:58 PM
The Unsettler
stomachmonkey's Avatar
Possible, could be a better quality power supply with a better fan.
Old 12-20-2011, 06:23 PM
19 years and 17k posts...
azasadny's Avatar
Sometimes the failing power supply can take out the systemboard and you may see leaking capacitators. This just happened to an old PC that I was repairing for a friend.
Old 12-21-2011, 07:52 AM
