Very simple DIY project. Once the cover is off, it's just 2 or 3 minutes. Test output voltage 1st.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Detached Member
$69.99 and I'm up and running. Thanks guys!
Hugh |
Senior Member
Same here, had it happen a couple of times...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
So what was it? I voted power supply too.
Bunch of old cars
Detached Member
Power supply. Surprisingly, the puter seems to run quieter as well.
Hugh |
Good for you Hugh. You got luckier then I. When my power supply died, it took out my mobo.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
The Unsettler
19 years and 17k posts...
Sometimes the failing power supply can take out the systemboard and you may see leaking capacitators. This just happened to an old PC that I was repairing for a friend.
