1.367m later
Software install problem, any suggestions?
I'm trying to install and older version of Dreamweaver on my laptop.
Laptop specs: Windows XP service pack 3 3500+ AMD processor 1.58ghz 74.0g HD w/52.1g free 1.87g ram I've already installed this program on my desk top computer having almost identical specs. Windows XP service pack 3 3400+ AMD processor 1.99ghz 87.5g HD w/54.0 free 1.43g ram When I run the Installer from the disc I get this for about 20 minutes ![]() It very slowly progresses and then I get this ![]() I've emptied my temp file, defragged my disk and done a disk clean in an attempt to clean things up and free some space but I still get the error message. Any suggestions or ideas on what I'm doing wrong?
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
How much free space do you have?
Go to "My Computer", right click on the drive, and then click "properties". It should tell you how much free space you have.
1.367m later
52.1 free on the HD
1.367m later
Lets try this again. Any suggestions/
The Unsettler
Where does it think your Temp space is? Or rather, does it think your Temp space is somewhere other than it actually is?
Do you have an external drive hooked up to your laptop? Have you tried copying the disc to your hard drive and running from there? Did you turn off your virus scanner? Which version of CS is it?
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
You have admin privledges? If it is a really old version try Win98 compatibility mode. SP2 and SP3 created some issues that weren't there in XP and XP SP1.
Otherwise, is the CD scratched or marked up?
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Well here are my thoughts: The software is made by those wonderful folks at Adobe and it appears the want you to get a new version of the software, I.E. the message about getting another copy of the installer. Have you checked their website to see what they say? I took a look and it appears this is a very common problem with this software and unfortunately it also appears that there seems to be no fix??!! Here are what I saw several folks tried:
- use regedit and make sure to remove any and all references to the software. - disable ALL anti-virus and anti-spyware software then restart, make sure no residual DLLs or processes are running. - Download a copy of ISO Buster (I have used it for years) and pull all the files off the CD-ROM and then run the setup program without the installer. This seemed to work for several people. - Get rid of all "temp" files and junk by typing %temp% in the Run box and when the files and directories come up, delete everything. - Make sure you are an administrator or login as administrator. |
1.367m later
Excellent..That did it..I moved everything to my HD and ran it from there. Thanks for the help.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. Last edited by KevinP73; 03-02-2012 at 09:50 AM.. |
nevermind....
Glad you got it fixed.
