Here try this. It may take awhile....
Old 04-23-2012, 09:25 AM
Get a 4" razor blade scraper with replaceable blades for it. It is linoleum or sheet vinyl?
Brent
Old 04-23-2012, 09:42 AM
Zeke's Avatar
Originally Posted by Chuck Moreland View Post
Linoleum can have asbestos content. How old is the house?
Ya beat me to it.
I'd be a little nervous around that stuff until I had a sample tested.
You guys have to understand how asbestos gets airborne and into the lungs. Sanding is the absolute worst process when asbestos is present. Breaking apart AB sheets or blocks is the next. Breaking apart soft materials containing AB follows in severity. AB used in flooring is locked up pretty good. It's not like you are sanding brake shoes. Using heat is OK unless combustion occurs and AB is released.
A little mist from a spritzer is all the pros do even wrapped up in a cocoon and suited up. Dealing with the soft stuff, they might put a little starch and soap in the solution. As a contractor, I've had to take the old test. The new test is so ridiculous that I won't comply. I just avoid all interior work now.
Cleaning up a dirty job with a piss poor vac is more dangerous than the act of removing most of what we remove. At least, the exhaust side of the vac should have a hose going out the window. Best is to have a HEPA vac and they are more and more common to find for sale these days.
For future archival info, just wet anything down that is suspect and recover all debris responsibly and completely. Technically, it is supposed to be double bagged, taped up and labeled. Contact your local trash authority for disposal instructions. Just as a note, material containing lead such as paint chips or painted surfaces can be double bagged, taped and tossed into the regular trash.
Edit: Older paper backed vinyl sheet flooring can definitely contain asbestos. Ripping this type of floor up leaving part of the backing still stuck to the glue is hazardous. And some adhesives manufactured before 1978 may contain AB as a binder. Sorry if I mislead.
Old 04-23-2012, 09:54 AM
JavaBrewer's Avatar
I'm in the process of ripping out my carpet to install Pergo. I did the kitchen in Pergo a couple of years ago, and the wife loved it so much she wants the rest of the house done in it.
Wait a minute...what is happening to the existing hardwood that was under the carpet? You're not going to replace that with Pergo are you??
Looking at your picture again I would remove all the particle board and kitchen Pergo and complete the room with a match of the existing wood floor.
Old 04-23-2012, 10:06 AM
JW Apostate
trekkor's Avatar
Just run a flat bar/pry bar under the particle board.
No reason to remove the lino from the underlayment.
When the particle board breaks, score the lino with a razor knife.
It's easy.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 04-23-2012, 10:29 AM
Unregistered
sammyg2's Avatar
LOL, over the years I've sat through too many training classes on asbestos and other hazardous waste handling.
Lots and lots.
Even carried a CFR-1910.120 instructor certification but got tired of the BS required to keep it current. I'm still current to the technical level going all the way back to March 18th, 1991 according to the piece of paper.
BTW, according to the EPA if that floor covering does contain asbestos, he'd be breaking the law by scraping it up.
Gotta be trained and licenced for anything beyond a minor repair.
Old 04-23-2012, 11:30 AM
JW Apostate
trekkor's Avatar
I think 90 square feet is the limit before the haz-mat pros have to get involved on asbestos.
I could be wrong.
KT
'01 Boxster
Old 04-23-2012, 11:33 AM
AutoBahned
RWebb's Avatar
xlnt. point
cost me $30 to get mine tested (it was neg. BTW)
Old 04-23-2012, 12:19 PM
Zeke's Avatar
Lots and lots.
I won't argue with your credentials, but residential work gets a bye on some things. I studied the recent EPA lead laws to the extent that I read the entire 100 page document. I can't say that I have done that much regarding AB.
The newest residential (I have to emphasize residential, not refinery) laws permit owners to work on their own homes in whatever manner they please w/o breaking any laws. This is not the case for a contractor working in the home.
There may be similar provisions in the EPA asbestos code to allow an owner to work in his home (not his rental) and do asbestos work including abatement. He probably needs to disclose the fact if and when he sells, but that's another day.
The fact is, flooring can be a hazard and it can be handled w/o any drama with some awareness and a little common sense. This is not a high rise nor a factory. Trekkor is right, pull up the sheets and get rid of the whole thing.
Don't call out the asbestos marshals just yet.
Old 04-23-2012, 12:38 PM
Lots and lots.
Sammy,
When did AB become illegel to use in the US for flooring?
Old 04-23-2012, 01:10 PM
I went ahead and ripped up the rest of the particle board, which turned out to be a good idea because there was a small section of rot by the sliding door.
Old 04-23-2012, 01:52 PM
AutoBahned
RWebb's Avatar
keep that wood floor!
It will never match any new wood strips etc. you put down so you may want to go with some sort of contrasting material. I like Marmoleum.
Old 04-23-2012, 01:56 PM
Unregistered
sammyg2's Avatar
Sammy,
1977? Not sure, that's my best guess.
They still use it in some exhaust piping from water heaters and such, but it's encapsulated pretty darned good.
Old 04-23-2012, 02:51 PM
Unregistered
sammyg2's Avatar
I'm gonna have to take your word on that Milt, you know the residential side much better than I do.
Maybe I'm used to going overboard because the regulators are so gung ho about hanging industrial plants of every single regulation they can dream up.
Old 04-23-2012, 02:54 PM
RETIRED
Joe Bob's Avatar
Real linoleum ALWAYS has asbestos.....but nobody has a regulatory authority unless it's more than 160 sqyaure feet.
2012 ML350 3.0 Turbo Diesel
Old 04-23-2012, 04:06 PM
Thanks again for the help - the project is moving along smoothly (I probably just jinxed it...)
Old 04-24-2012, 06:10 PM
JavaBrewer's Avatar
Love the floor on the right...left side...not so much.
Old 04-24-2012, 09:32 PM
Personally, I like the look of the old stuff too. However, it has been abused and carpeted over several times over the years, and I don't think it was viable. Not only that, but only part of the house still has the old flooring, so one way or the other, the whole thing would need to be re-done.
Old 04-25-2012, 05:22 AM
Unregistered
sammyg2's Avatar
Where Asbestos Hazards May Be Found In The HomeSome roofing and siding shingles are made of asbestos cement.
Houses built between 1930 and 1950 may have asbestos as insulation.
Asbestos may be present in textured paint and in patching compounds used on wall and ceiling joints. Their use was banned in 1977.
Artificial ashes and embers sold for use in gas-fired fireplaces may contain asbestos.
Older products such as stove-top pads may have some asbestos compounds.
Walls and floors around woodburning stoves may be protected with asbestos paper, millboard, or cement sheets.
Asbestos is found in some vinyl floor tiles and the backing on vinyl sheet flooring and adhesives.
Hot water and steam pipes in older houses may be coated with an asbestos material or covered with an asbestos blanket or tape.
Oil and coal furnaces and door gaskets may have asbestos insulation.
That's prolly where I got the 1977 from.
According to this site, one company was still using AB in vinyl flooring until 1980.
Asphalt-based asbestos floor tiles and plastic or vinyl-based asbestos flooring were popular in the U.S. in the 1940's - 1970's and were produced by some manufacturers (Armstrong) as late as 1980. Some asbestos-containing flooring products were manufactured (we estimate) as early as the late 1920's.
How to identify asbestos floor tiles or asbestos-containing sheet flooring - Asbestos Visual Identification in buildings: How to find recognize, and identify asbestos or asbestos-containing materials in buildings by visual inspection methods - text a
Old 04-25-2012, 09:31 AM
RETIRED
Joe Bob's Avatar
Asbestos was banned then there was a lawsuit, they relaxed the ban.....now they advertise the use in products with the term "With Chrysotile Fibers"....look it up.
BTW....I wrote this and enforced it....this is the minimal Federal Law. Local regs can be more stringent....
http://www.sbcapcd.org/biz/asbestos.htm
Old 04-25-2012, 09:42 AM
