JW Apostate
trekkor's Avatar
OBD II live data
Looking at the TPS values in real time.
3.5% at idle and 75% at WOT.
Shouldn't be 0-100%?
Also the MAF shows a value while the car is off.
Wonder if those two components should be replaced?
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 05-22-2012, 07:48 PM
canna change law physics
red-beard's Avatar
I never submit my TPS reports
I recently picked up a couple of Bluetooth OBD II transmitters. There are lots of cool Android and iPhone apps to track and record this stuff in real time.
James
Red-beard for President, 2020
Old 05-22-2012, 07:58 PM
My tps values also don't go from 0 - 100. I think that's pretty normal depending upon the vehicle and reader. I bet if you spoke to other folks with the same vehicle, they'd see similar readings.
Well, there's always atmospheric pressure, right? So should you always get a reading? My car doesn't support a maf reading through the obdii, so I can't compare.
Old 05-22-2012, 07:59 PM
JW Apostate
trekkor's Avatar
'98 VW Jetta, here.
I gave that some thought, but there was a trouble code indicating MAF value problems.
I cleared the code 0103, it hasn't returned yet and did not trip the CEL.
KT
'01 Boxster
Old 05-22-2012, 08:11 PM
JW Apostate
trekkor's Avatar
Uhhhh, yeah. What's happening?
I really need those TPS reports...
KT
'01 Boxster
Old 05-22-2012, 08:14 PM
You do not have permissi
john70t's Avatar
I don't remember much from school, but....I think....the sensors should send a small value back to the computer, even when inactive, to show they are connected and returning a signal voltage.
Not sure if 3.5% is the usual low value.
That 75% at WOT might be some cable slack(?). The potentiometer inside can get gummed up with carbon and get lazy.
You might be able to check the full TPS range using the scanner with KeyON-EngineOFF using the pedal and/or pushing the pivot.
Old 05-22-2012, 08:22 PM
JW Apostate
trekkor's Avatar
I ran the test with key on only.
Maybe I should disassembled the throttle body and MAF and clean them thoroughly.
KT
'01 Boxster
Old 05-22-2012, 08:25 PM
Don't forget the new cover sheets.... Did you get the memo?
Old 05-22-2012, 08:26 PM
john70t's Avatar
A day at the office is like using the restroom.
It's not finished until the paperwork is done.
(grandpa's joke)
Old 05-23-2012, 05:52 AM
Super Moderator
cstreit's Avatar
Never seen one go from 0-100... Mine reads 0-75
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 05-23-2012, 07:16 AM
JW Apostate
trekkor's Avatar
Thanks for the post.
That helps.
KT
'01 Boxster
Old 05-23-2012, 10:03 AM
BReif61's Avatar
I know at least on my mazda that "full throttle" is nowhere near 100%.
-Brad
2002 Carrera2
1986 944 Turbo
Old 05-23-2012, 10:53 AM
