darnellsgarage
Water Filter for Air Compressor
So much water in system that my media blaster keeps plugging up. Have a water trap, but is not enough. What are you guys using?
don |
Gallatin, Tennessee
These are what I used at the place I used to work at. Not cheap but they work great.
Wilkerson - Coalescing Filter Products Dave |
The media could also have too much water in it. When was it changed last?
Bunch of old cars
UnRegistered User
It is probably a stupid comment but here we go anyway!
How often are you draining your tank? Short of a refrigerated drier, you could install what amounts to a condenser on the wall. A series of parallel vertical runs connected with 90s with a drain at the bottom of each.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
darnellsgarage
Media new ( aluminum oxide). Might have 1.5 hrs use. Limited grease. 80 gal tank, which I usually drain after each significant use, or once a week. I have one of those bowl type filters, doesn't seem to catch a lot. I have an Eastwood soda blaster too which works better as it as another filter on the unit, and that seems to catch a lot.
don |
75 feet of 3/4" pipe helps a lot also.
Rick 88 Cab |
When I'm doing something for which dry air is important, I add a 50' length of hose in a tub of water right out of the compressor, before the air dryer. One time I even added ice to the water, but I don't know if it made a difference or not. My air line goes out of the compressor and underground for about 20'.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
