Originally Posted by Superman View Post
Interesting. If you filled a balloon with one cubic meter of air and put it on a scale, then subtracted the weight of the balloon, you'd have your answer. In terms of "weight."
Only if it's a mylar balloon. Rubber balloons are elastic. Therefore they exert pressure on the air inside. To blow up a balloon, you have to have more air inside than the volume at the same conditions to actually expand the balloon which means that you have more air inside the balloon's space than you would have if the balloon wasn't there.
Old 06-13-2012, 07:31 PM
Senior Member
Superman's Avatar
No, you would just have just the weight of the rubber assuming the air inside the balloon is the same density as outside.
If so, then one cubic yard of air has zero weight.
Mocha 1978 911SC. "Coco"
Old 06-13-2012, 07:39 PM
Senior Member
Superman's Avatar
Okay, so if you filled a mylar baloon with air, at exactly one atmosphere of pressure, and if you set it on a scale and the scale read exactly the weight of the mylar baloon, then the air inside has no weight. It might have mass, but no weight.
Old 06-13-2012, 07:41 PM
Max Sluiter
Flieger's Avatar
Good catch! I hadn't thought of that. So the air inside can't be at the same density.
The scale would read the weight of the air and balloon minus the buoyant force on the whole thing. That means the air inside the mylar balloon would have zero net weight and the weight of the rubber would be reduced by a tiny amount equal to the weight of a volume of air (same density as inside and locally outside the balloon) equal to the volume of the mylar.
Old 06-13-2012, 08:08 PM
slodave's Avatar
I'll just add this in here for the heck of it.
At sea level, the standard atmosphere consists of a barometric pressure of 29.92 in. Hg. (1013.2 millibars) and a temperature of 15*C (59*F). This means that, under these standard conditions, the weight of a column of air at sea level will weigh 14.7 lb/in².
Old 06-13-2012, 11:00 PM
AutoBahned
RWebb's Avatar
Dave, how much is that in Pascals?
Old 06-13-2012, 11:30 PM
slodave's Avatar
Turbo Pascal?
Old 06-13-2012, 11:32 PM
slodave's Avatar
I had to look things up.
101325 Pa
Old 06-13-2012, 11:43 PM
Gon fix it with me hammer
svandamme's Avatar
At that point, I would begin to wonder whether the "mass" of the balloon would be different from its "weight."
Well no.. because the content of the balloon were already on the scale before you put the balloon with the air in it on the scale.. + you got all the weight of all the air above the balloon, still on the scale, on top of the balloon.
so in short, you can't weigh "air" with just a scale.
unless you first put the scale in a room that has been pulled vacuum..
and then you put your filled balloon in there.
Ideally you take a non elastic , box that is 1 square meter..
close that box at regular athmospheric pressure
Seal it
take it to a vacuum chamber
reset the scale to zero
put the box on the scale
weigh it
open the box
reset the vacuum in the room
weigh it again
subtract.
Old 06-14-2012, 04:23 AM
scottbombedout's Avatar
Wouldn't the balloon explode?
88 carrera
Using the teutonic shift method since 1990.
Old 06-14-2012, 08:21 AM
Max Sluiter
Flieger's Avatar
We did the vacuum thing in a measurement lab as a demonstration. Marshmallows get really big. We did not try balloons.
We had to measure the mass of diesel fuel we were going to combust in a bomb calorimeter and we had to correct for the bouyancy since we measured in ambient air and to get the mass more accurate. The scale also had a box around it to keep the air currents from causing noise in the measurement.
Old 06-14-2012, 12:15 PM
Jim Bremner's Avatar
I'm sure that LA Smogair weights in more than say air from Idaho.
Old 06-14-2012, 12:33 PM
Detached Member
Hugh R's Avatar
If you have a hummingbird in a box on a scale and the box weighs 10 grams and the bird weighs 10 grams, (total weight of 20 grams) and the hummingbird then takes off and hovers inside the box, what is the weight reading on the scale?
Hugh
Old 06-14-2012, 02:08 PM
10 grams. it took me a second to get the hummingbird into the box. I had to readjust my tare since my box weighted in heavier.
Old 06-14-2012, 02:27 PM
Detached Member
Hugh R's Avatar
Uh, no. Waiting for other responses.
Hugh
Old 06-14-2012, 02:52 PM
The birds wings will create downward thrust equal to its own weight?
88 carrera
Old 06-14-2012, 02:58 PM
I'm with Bill
Rick V's Avatar
Equal or greater than?
Old 06-14-2012, 03:00 PM
Dunno Rick, I am still waiting to see if my original calculation should include the 43% oxygen present in the wood
88 carrera
Old 06-14-2012, 03:10 PM
I'm with Bill
Rick V's Avatar
Nerd
Old 06-14-2012, 03:31 PM
AutoBahned
RWebb's Avatar
Initially, it will be the wt. of the box plus the wt. of the increased pressure downward caused by the wing beats
Later on, it will be the wt. of the box + wt. of the hummingbird
Much later on, it will be the wt. of the box + the non-water wt. of the hummingbird
Old 06-14-2012, 03:41 PM
