The lower deck is 2 feet high so apparently you don't need handrails or guards on those stairs. I know that if it is icy in winter then I wish I would have put handrails/ guardrails on. However I will post pics later so u monday morning quarterbacks can have your say.....again. Thanks for your input and humor!
3 risers or 30" calls for handrails. If the distance from the top of the deck to the patio is 24', you should be able to make three 8" risers work (with handrails).
Ever seen wiring in Mexico? They live in concrete houses for a reason. Don,t connect to the public water system without meeting minimum code to stop you from affecting the safety of others. Things like a vacuum breaker to prevent back flow into the system from your pool or ? Don,t connect to the sewer system either. Leave things like the unsafe stairs and keep everyone off your property. Don,t expect reasonable insurance rates either .You want to opt out so self insure. Some states require tradespeople to be licensed as well as having a permit for any changes to the structure.this might seem onerous and interferring but it is Not usually a problem meeting minimum code. Too many people watch a TV show and pick up a hammer and think thats it. What about resale Leave your defects behind because they were good enough for you??
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
True that. The top step of less than 4" and not matching the other rises is very dangerous.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Code or no code. That is not the question.
Properly built stairs are safe and feel natural when walking on them. Handrails make sense as children, the elderly and intoxicated folks need all the help they can get. You should be able to walk across the deck holding a large platter of brats, wings and ribs in one hand, your cocktail in the other, without the fear of stumbling down the stairs and having to spend the next half hour picking dirt and grass clippings out of your delicious, well prepared meal.
Randy '87 911 Targa '17 Macan GTS |
Now in 993 land ...
![]() G |
The other two I have cut two inches off each stringer and drilled new holes and made the height between the steps the same. I have added two vertical rails to the handrails so some idiot kid cannot stick his head in there. There are no pics. I am putting a 3 foot platform under the steps where the height of the deck is over 2 feet. |
You do not have permissi
The Japanese used to build with cedar without nails using mortise and tenon. This keeps people from slipping on ice, falling forward, and snapping both legs in two. A good code, IMO. |
Slackerous Maximus
Can you get away with not having a proper footing?
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
