LinkBack Thread Tools Rating: Thread Rating: 5 votes, 3.20 average.
Well.... the body work will come last, I do agree that the stickers on the rear look a little suspect.... right now we are removing the engine because a headbolt is broken..... These cars are put together well, every nut, bolt, washer etc is tight, and more than half of them seem to break. I will say this, however, that the engine removal process is not as bad as I thought it would be... Can the engine be assembled completely before putting it back in the car(wiring harness issues)?
When the common bond is a Porsche, the people who own them are even more interesting than their cars.
Old 10-30-2012, 04:52 PM
Banned
speeder's Avatar
Porsche flat sixes do not have head bolts. They have head studs, with nuts on the ends. Make sure that you send it to someone good or start a thread on the 911 tech board here and ask about a million questions. If you are not familiar with Porsche air-cooled engines, all of the small block Chevy knowledge on earth will avail you nothing.
It is not a *common sense needed only* or general mechanical knowhow will do. These engines have issues that are unique to them and specific to the model and vintage of the mill you are working on. It's nothing you can't handle if you know what you're doing, but that's a big "IF".
Good luck!
Old 10-30-2012, 06:46 PM
Banned
speeder's Avatar
And yes, the engine is removed and installed complete for the most part. In most models, 100% complete down to the air cleaner.
Old 10-30-2012, 06:48 PM
Now in 993 land ...
aigel's Avatar
Get Wayne's Engine rebuild book. Also get the Bentley Manual for the SC.
You should NOT be breaking any hardware except for head studs. What are you trying to do? Replace head studs? Please start reading here with a search for "broken head studs".
I think you really have something here with that car - please make sure you educate yourself on the details before taking it apart or spring in for a good mechanic.
JMHO - very cool car.
G
81 SC (sold)
Old 10-30-2012, 07:10 PM
A930Rocket's Avatar
Do not contact Motor Meister for your engine needs!!!
Old 10-30-2012, 08:34 PM
Banned
speeder's Avatar
I was thinking the same thing but didn't even want to mention their name. That would be tragic I they got their greasy mitts on this car.
Old 10-30-2012, 09:24 PM
Sounds like a boost gauge.
Originally Posted by Originally Posted by 81Kremer930
The car is equipped with a large gauge where clock should be, the red needle is set at 1.2bar.... I'll prolly stay around 1 however.. I am not trying to hotrod it, just enjoy the ride.
Yeah, specifically a VDO-style boost gauge with a tell-tale. Don't suppose you got the little triangular key to re-set it...
Good luck running a CIS 930 at 1.2 bar. That's something people did in the 80's. You really shouldn't touch the boost dial unless you know what the effect is on AFR's - and the numbers you're looking for on a 930 (hint: 13 at full chat is way lean).
There's better/safer ways to make 100+HP more than stock than turning up the boost. You can make 370 at the rollers with stock boost, stock valves/ports, stock manifold and CIS.
'77 S with '78 930 power and a few other things.
Old 10-30-2012, 09:39 PM
That's a lot for stock.
Old 10-30-2012, 10:43 PM
Last time I check, North Hollywood still has the key.
Kreme 930,
The red needle is stuck up there is because the last time that was where the highest boost recorded. Try not to get it near there unless its turned.
Old 10-30-2012, 10:47 PM
Dottore's Avatar
the 80's for me was kindergarden and eagles music.
That sounds rather good. You coulda done a lot worse.
_____________________
These are my principles. If you don't like them, I have others.—Groucho Marx
Old 10-31-2012, 01:03 AM
Head stud is correct.... I feel confident in my tech here... the only thing we are doing is replacing the stud and nut... the damn thing doesnt even leak! I'll make sure the car is tuned for 1.0 Bar max... Do these motors run afr's like other turbocharged cars ie(lancer evo/wrx sti, these I am much more familiar with)?... wide open at 10.9-11.5? Keep it really rich? I appreciate the help...
Old 10-31-2012, 04:35 AM
Bland
unclebilly's Avatar
Shouldn't this have had the fiberglass rear bumper with the flipped tail lights?
Old 10-31-2012, 05:22 AM
Double Trouble
targa911S's Avatar
send it to henry..
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 10-31-2012, 05:38 AM
~370 at the rollers, as compared to 300 at the crank for RoW (or 265 for US-spec 86-up), needs a modern turbo, decent intercooler, improved headers, decent cams (SC work well) and uncorking the wastegate. All of which improves the car immensely both on and off-boost, only downside is the the heat kind of sucks after. Drat.
No need to address the 34mm(!) inlet ports, pancake manifold or boost for those power levels. Approaches taken for the next 100-150 HP generally diverge quite widely...
Old 10-31-2012, 06:59 AM
least common denominator
scottmandue's Avatar
I don't know what it is but I know what I like...
That is a super nice car!!!! I am extremely jealous!
RE: The front bumper... I'm going out on a limb here... looks a little like a 944?
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 10-31-2012, 07:12 AM
We are going to update turbo with a K27-7200, turbokraft intercooler, and fabspeed heater box/headers and exhaust. I asked Kremer about the body work, the front and rear bumpers, those guys are hard to understand and getting any kind of a response is difficult as well... the model is Kremer 930, the 935's has the flipped tail lamps and fiberglass rear bumper as far as I understand. The front bumper I have never seen before, consequently neither has anyone else I have spoken to.
Old 10-31-2012, 07:14 AM
Pump gas and 1 bar of boost?
I have all the bolt ons with major internal work, 3.4L and SC cam. 1 bar boost, pump gas and barely got 364 at the wheels. I have heard from some that they will get upwards of 380-390 at the wheels.
Old 10-31-2012, 08:59 AM
I am not as interested in power numbers as I am having a nice, reliable, fun to drive car... It will be a pump gas car for sure set at 1.0 bar. I am sure it will be fast enough while keeping it relatively stock. I'd love to be able to race one, but I don't think this car is the right choice for that activity... maybe in the future I'll put a twin turbo motor in the convertible....
Old 10-31-2012, 09:04 AM
Banned
speeder's Avatar
That's good. Any relatively competent tech can work on that car as long as he's not a know-it-all who's too smart to read a FSM or ask someone who really knows. I build really fantastic engines myself because I'm the opposite...I ask so many questions and get so deep into the minutia that it drives everyone around me crazy.
It takes a new pair of glasses to work on engines that have 35lb. torque on the head fasteners, (or whatever the hell it is).
Old 10-31-2012, 10:42 AM
Well here are a few questions... while reading about this engine(torque specs, etc)... the copper o rings at bottom of jugs, should they be replaced? Should the nuts on the head studs be replaced? And what is this Loctite 573 stuff(goes between rocker box and jug assy)? I spoke with a local Porsche Tech, he's probably on here somewhere, told me to use this paste stuff from VW. Other than that(so far), these engines have a rather great design, considering they make more power stock than most other v8, v10, or v12 of the time.
Old 11-01-2012, 05:04 AM
