Wandered off somewhere...
Drdogface's Avatar
Boolit casting
I recently bought an original 1861 Springfield rifle from the Civil War era...58 cal muzzle loader but is a rifled bbl. I used to shoot these originals back in High School and I want to shoot this one. Now I have loaded and cast bullets for BPCR shooting (BP cartridge) out of 20:1 Lead:tin but something tells me that pure lead would be required for shooting this old lady.
I have pure lead but would have to drain my lead pot to start over with pure stuff so let me know what you experienced guys think.... Pure lead or 20:1
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 12-16-2012, 06:32 PM
Pure lead is the only way to go for these. There are a couple of problems if you try to use anything harder. One is that harder alloys will not bump upon firing to properly to fill the rifling, despite the huge hollow base on the Minie ball. This will make the ball skip and skid down the bore, leading it pretty bad in the process. That, and pure lead shrinks the most coming out of the mold; Minie molds are sized to allow for easy loading in a fouled bore with pure lead. Anything harder that shrinks less will kind of giving you a "double whammy" as far as loading ease - the bullet will be bigger and harder, both of which will make it harder to load.
The standard load for these is 60 grains of FFg. Make sure you fill the hollow base with lube in addition to filling the "lube grooves", such as they are. They are really more "scrapers", meant to help keep the bore cleaner for easier loading. Lot of guys don't put any lube in them, since it mostly comes off in handling anyway - they rely on the big blob in the hollow base.
I never have liked casting Minie balls. Monkeying with the base plug is an added step that just slows me down. Fortunately, being a muzzle loader, it's hard to go through too many of them, so that helps a bit.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 12-16-2012, 08:32 PM
Drdogface's Avatar
Thanks Jeff... I was hoping you would reply. I guess I knew I should use pure lead but my pot is full of 20:1 so I'll have to use another. I have plenty of pure lead... Yeah, the base plug is a PIA but this mould only throws 320gr Minnies for plinking. Did not know about filling the hollow base...thanks for that. This is a very nice original 61 Springfield and should shoot well. I won't shoot it much at all but would be fun to play with for a bit. it's mostly just a treasure to have around.
Mark...
Porsche Boxster S
Old 12-16-2012, 08:39 PM
I'm envious, Mark. Those are an awful lot of fun to shoot, and it can be surprising just how well they do shoot.
I keep three of the big 20 pound Lee dipping pots around, all with a different mix. 20:1 for the black powder cartridge rifles, wheel weights for the handguns and modern rifles, and pure lead for the front stuffers. Those pots are so darn cheap I figured I could spring for three and still not have into them what a single Lyman, RCBS, or SAECO would set me back. They are great pots, too - I've never had a lick of trouble with any of them.
Jeff
'72 911T 3.0 MFI
Old 12-17-2012, 04:43 PM
Drdogface's Avatar
Jeff,
One of my good friends is an antique gun dealer. I have visited his man cave many times as well as his sales room...all very well hidden and locked in his home. On my most recent trip to see him I mentioned my past life experience with re-enactments when we used to shoot these original rifles with blank charges, of course, but we also shot matches with them. He said he had several and I bought one right on the spot. Gorgeous piece for not much more than an Italian copy.
I was casting some 38-55 yesterday but had my new Mini ball mould so tried a few just to see. I do need another pot with pure lead for sure.
Mark...
Porsche Boxster S
Old 12-17-2012, 04:53 PM
Hey, it can't hurt to try. One thing I've learned in the black powder game - "never say 'never'..." Who knows, your rifle may do just fine with 20:1, or at least well enough to entertain yourself. That's really all we are after anyways, playing with these old guns. Let us know how the old soldier likes 'em.
Jeff
'72 911T 3.0 MFI
Old 12-17-2012, 05:01 PM
Drdogface's Avatar
OK then....I'll give it a go. Film at 11.
Mark...
Porsche Boxster S
Old 12-17-2012, 05:05 PM
John Rogers's Avatar
I use 20:1 for everything except for round balls and it seems to work. The .451 bullets for both the Gibbs and the Tryon rifles use a lubed fiber wad over the powder which serves the same purpose as the milk carton wad in my .459 sized 45-70 BPCRs (Sharps and Rolling Blocks). I did make some round balls from 20:1 and they were a tad lighter and did shoot a couple inches higher at 50 yds but at 100 yds had dropped right back to where the pure lead balls hit.
I use 70 grains of Goex FFG in the muzzle loader Gibbs and Tryon out to 300 yards and if over that I use 90 grains. I use 68 in all the BPCRs out to 800 yards.
Old 12-17-2012, 06:07 PM
Drdogface's Avatar
John...
Cool..thanks for that. I shoot round balls in my Ruger Old Army pistols..pure lead. I'll try the 20:1 in this '61 Springfield. I like the idea of an greasy over powder wad too. Guess I should have cast more yesterday.. Used to shoot BPCR Silhouette and Çreedmoor all the time until my left shoulder went south. We were casting 38/70 groove-less bullets and winning at 1000 yards.
Mark...
Porsche Boxster S
Old 12-17-2012, 06:31 PM
winter-hater club member
nynor's Avatar
1000 yards with black powder?! hats off, sir.
"COOL PRIUS!" - Nobody Ever
Old 12-17-2012, 07:19 PM
The first of the "real" guns I bought was a home gunsmithed original Rolling Block with a 32 inch heavy Badger Barrel built about 15 years ago and sat for probably 10 or so. The builder had bad joints and had installed a recoil pad on a beartiful piece of American Walnut. The builder was about 6'8" and unfortunately for me when I finally got the loads worked out using a LeadSled and started to shoot off hand I found I could not reach the trigger! So I took the pad and about another inch off the stock and cast in nearly a pound of lead to balance the gun. My mentor also told me to use a straight cut butt on the 45-70 guns as it would affect me less and it seems to be true. I have a Sharps that is curved quite a lot (like a Winchester 74) and it does make my shoulder sore after 50 rounds or so.
Before anyone chimes in on to never use a LeadSled, I use high density foam behind the stock to absorb the shock and it takes ME out any load development equation.
Old 12-17-2012, 07:27 PM
Drdogface's Avatar
Well, thanks for that but it's not really as hard as you might think. It does take discipline to be sure and knowledge of wind deflection but you can hit a target that far away..BTW, we were using ladder style peep sights...no scopes and always had a spotter watching wind and calling changes in sight settings. Team effort...
Mark...
Porsche Boxster S
Old 12-17-2012, 08:09 PM
Drdogface's Avatar
Neat story John. I know what you went thru and even though crescent butt plates look cool they are not good for this game. I used a strap on shoulder pad when I shot 45/90 but I changed to 38-70 and never used a pad again. Big difference. I just don't shoot prone anymore because of left shoulder problems... I miss the game a lot... I won one Ca State BP Creedmore match before I had to quit...great memory..
Mark...
Porsche Boxster S
Old 12-17-2012, 08:12 PM
nynor's Avatar
i know how hard it is with my .308 and i have a .50 black powder rifle. with peep sights, again, hats fricken off!
Old 12-17-2012, 08:16 PM
Drdogface's Avatar
Well thank you again... I'd love to show you how it's done and let you try it. It does take some dedication though. You must cast your own bullets because you cannot buy bullets good enough to be accurate at that distance. Loading the case is precise as well...all very complex and time consuming, but that's what you gotta do to be that accurate. Even after I had cast 100 bullets....which may take most of a day...you need to let them 'cure' for a few weeks. Then loading 100 cartridges would take most of another day just to measure powder, compress just so, and so forth. It's a very precise sport...but fun.
Mark...
Porsche Boxster S
Old 12-17-2012, 08:39 PM
nynor's Avatar
hell, i'd like some instruction at 1000 yards with .308 . cheers!
d.
Old 12-17-2012, 08:48 PM
Senior Member
You guys are not helping at all. I sure miss shooting the .45-70!
Old 12-17-2012, 09:22 PM
nynor's Avatar
what is the weight of the bullet with the 38/70?
the .45-70 is a really cool firearm, also. someday....
Old 12-17-2012, 09:25 PM
Drdogface's Avatar
38-70 bullet we shoot is groove-less but hot dipped in a special lube...dunno the formula for it... Wt is 172 gr. Mould made by Paul Jones...best mould maker I know of and perfect concentricity. 38/70 is an original old cartridge but only ever chambered in the Win 1886 and only for a few years. Case is slightly necked down 45/90 and trimmed a bit. BBL. custom made by Dan Lilja. I'll take a pic of a round later and post it here
Mark...
Porsche Boxster S
Old 12-18-2012, 07:16 AM
Drdogface's Avatar
Ok...for anyone interested here are three cartridges. Typical 45/70 on the right, 38/70 in the middle and 45/90 on the left with 540 gr bullet seated out to engage the rifling.
Mark...
Porsche Boxster S
Old 12-18-2012, 08:11 AM
