AutoBahned
RWebb's Avatar
Computer Boot problem - XP
I have an old Dell 8300 running XP that will no longer boot. When you turn it on, the Dell logo does appear and the bar below the logo fills over a few seconds (maybe that relates to POST or drivers loading - I dunno).
However, I never see anything having to do with Windows appear on the screen -- it simply goes blank after the bar fills.
Any ideas on what might be wrong? or what I might try by way of fixing it?
Old 01-17-2013, 01:20 PM
Scott R's Avatar
Press "F2" before that bar completes, enter setup and see if your hard drive is being detected still.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-17-2013, 01:36 PM
If you have the XP CD/DVD you can boot from that and check the files on the drive as well if it is still recognised. Use the repair console and not the repair install.
Brent
Old 01-17-2013, 01:55 PM
first things first. open the case and vacuum/blowgun all the dirt out.
try hitting f8, f10 or f12. oem usually designates one of those to go to boot menu. from there it'll show you the messages as it boots.
i would expect maybe a corrupt system file or something
Old 01-17-2013, 02:47 PM
coulda, woulda, shoulda
johnco's Avatar
with my old laptop it was 1 of 2 memory chips bad. pulled the bad one out and everything back to normal
John
74 911s
Old 01-17-2013, 03:11 PM
AutoBahned
RWebb's Avatar
did that - HDD is being detected (in fact, I think part of the bar being filled relates to the HHD and some drivers)
krystar - also hit F12 and nothing looks odd in boot menu; no log of problems either
Old 01-17-2013, 03:24 PM
Try the Del key.
Old 01-17-2013, 03:28 PM
Scott R's Avatar
This is what I would suggest next as well, you start eliminating pieces one by one until it boots. Memory, cards, dvd drives, etc..
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-17-2013, 04:44 PM
least common denominator
scottmandue's Avatar
Dell's prefer flip flops to boots dude!
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 01-17-2013, 04:57 PM
AutoBahned
RWebb's Avatar
shouldn't it generate an error for me to see if it was one of those things?
I also think the video is on the main board, but will see...
Old 01-17-2013, 06:10 PM
Scott R's Avatar
Dell and others use those splash screens over the BIOS post sequence. You used to be able to press ESC and see the post but I think they took that away too.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-17-2013, 06:31 PM
johnco's Avatar
my laptop would do exactly as yours. get to the same point and shut off each time. after a lot of research on the hp site, I saw it was recommended to pull one chip, try boot, the replace it and remove other. this worked. also checked them on another laptop and got the same problem using the bad chip
John
74 911s
Old 01-17-2013, 06:32 PM
AutoBahned
RWebb's Avatar
found the reinstallation CD, which I think dates to 1879, so I can try that next time I go to the downtown office
thx all
Old 01-17-2013, 09:33 PM
