Targa, Panamera Turbo
Worlds Smallest Gas Engines! Serious Skill Here Guys...
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
![]() This 1/3 scale billet machined, supercharged Chrysler 300 Hemi racing engine from the 1960s was built by James Weber. It has a 1.0" bore and 0.90" stroke displacing 5.65 cubic inches. The engine burns gasoline or methanol (methyl alcohol) on dual electronic spark ignition and incorporates a two-stage pressurized dry-sump lubrication system. It will turn around 12 grand and uses a couple of computer cooling fans on the radiator to keep things cool. Note the professional looking throttle and gauges on the stand. ![]() Here's a V-8 and a half ; a ? scale Ferrari V-12 by Jeron Classic Motors. It has double overhead camshafts, burns methanol on glow ignition and is equipped with two oil pumps for dry sump lubrication. All six carburettors function and are linked together for smooth operation. The heads and block are about 7-1/4" long. Only a few of these were made before the company went out of business, so it's pretty rare. Like many of the engines you see here, it is on loan to the Craftsmanship Museum courtesy of Paul and Paula Knapp and their Miniature Engineering Museum . ![]() Here's another twelve. The late Al Ingersol built this Curtiss D-12D 1/6 scale V-12 airplane engine completely from billet stock and also built a model Curtiss Wright P 6E biplane to put it in. The engine is only 9" long and weighs 6 pounds. It has a 0.80" bore and 1.062" stroke, displacing 6.46 cubic inches. One of the more popular model V-8 engines over the years has been the Challenger. This one was built by RonColonna. Casting kits are still available for this 1/3 scale engine through Coles Power Models, although it is definitely not a beginner project. Several V-8 engines by Ken Hurst are displayed at a model engineering shows like the recent Western Engine Model Exhibition (WEME) in Vallejo , CA . How about that supercharger! Behind the first engine is his blue Challenger V-8. The 103 cc engine sounds great running on a mixture of white gas and high octane racing fuel. Eugene Corl built this 1/3 scale Chevy V-8 using engine castings he produced himself. The engine is seen here at the Gas Engine Antique Reproduction Show (GEARS) in Portland , OR . ![]()
Puny Bird
Big deal.... your cellphone will weigh 60Lbs once the EPA is finished with it.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
On a great circle route
How often do you have to change the oil?
Russ |
I imagine the writer of that story isn't a numbers person.
'87 911 GP White "casper" '79 930 Copper Brown Metallic "beast" '93 968 Amazon Green Met "moby" '97 Esprit V8 "flat eric" '97 993 Speed Yellow "tbd" |
![]() ![]() Quote:
![]() Here you can see the cylinder heads of the Moyer 327 plus the stamped oil pan and front cover. Some parts inside the engines are made to scale like the 30-30 Duntov camshaft, but some things have to be modified to make a small engine run. Electricity and fuel molecules don't scale, so some parts have to be slightly heavier or larger than exact scale would dictate. Getting a small engine to run requires skill and careful work; getting one to run well is an art. ![]() Here's a shot of Jim's tiny Corvette V-8 being test run. He is now working on a 1/6 scale Chevy 409.
![]() Paul Knapp built this great looking version of the Conley V-8. It runs twin carbs on a fully functional Roots style 671 blower and will turn 12,000 RPM on methanol. Note the nicely painted and highly polished finishes on this beautiful engine. (Did you notice that the ignition switch even has its own set of keys like a real engine?)
![]() Quote:
![]() Quote:
![]() Quote:
![]() Quote:
As a Machinist since I was 12 years old, all I can say is..Wowawoowa!
Formerly from ratslist. AMG E 55..2002. Lotus Esprit SE. 1990 |
I know right!
I hope these Masters are still in the working field and pass on what they know.
My experience indicates much selfish kept knowledge. Such a waste.
I think I could buy a 1:1 that needed help...but still its very cool!
závodník 'X'
Wow Wayne!
“When these fine people came to me with an offer to make four movies for them, I immediately said ‘yes’ for one reason and one reason only… Netflix rhymes with ‘wet chicks,'” Sandler said in a prepared statement. “Let the streaming begin!” - Adam Sandler |
cycling has-been
regarding post # 1 - I call BS - early April Fools - no way
"Best Answer - Chosen by Asker Sounds serious. To check a number or two, my portable PC uses about 50 watts of power. Gasoline has energy capacity of 35 MJ/L. A "squirt" I'll define as 1 cm³, and there are 1000 of these in a liter. So a squirt of gasoline would hold 35 kJ of energy. A gas engine is 30% efficient, about, so that is 10 kJ available to power the laptop. 50 watts is 50 J/s 10 kJ / 50 J/s = 200 seconds, or 3 minutes. Hardly the months promised. For 2 months, 5e6 seconds, using the numbers above, you would need 50 J/s x 5e6s = 250e6 J. converting that to gasoline, that is 250e6 J x 3 / 35 MJ/L = 15 liters of gasoline, hardly something you would want to carry around with your computer. My guess would be the engine is real, but the article was written by a news reporter who exaggerated things a bit. "
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 03-22-2013 at 05:43 AM.. |
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
cycling has-been
sorry r-b, but I gave you 59 days, 11 hours, and roughly 52 minutes, and still had not heard from you.
I figured you were going to pass on this one. I won't be so hasty next time. ![]() Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 03-22-2013 at 08:20 AM.. |
