Dottore's Avatar
iPad question...
....anyone know how to disable the "auto-rotate" feature on the screen?
_____________________
These are my principles. If you don't like them, I have others.—Groucho Marx
Old 01-26-2013, 11:39 AM
motion's Avatar
Slide the lock button on the side.
'95 993 C4 Cabriolet
Bunch of motorcycles
Old 01-26-2013, 11:40 AM
Or put 4 fingers on the screen and move them up the screen so you see the brightness adjustment. Slide left and touch the lock. That will also lock the screen
Old 01-26-2013, 12:06 PM
Instead of using four fingers, you can also double click the button.
Old 01-26-2013, 12:11 PM
Dottore's Avatar
None of these tips seem to work. I'm using a first generation iPad. Does that make a difference??
Old 01-26-2013, 02:45 PM
craigster59's Avatar
Try one of these, beat it at it's own game....
Old 01-26-2013, 02:54 PM
Can't you also disable it from within settings?
Old 01-26-2013, 02:59 PM
Dottore's Avatar
iPad. No. Can't find any settings to disable.
Old 01-26-2013, 03:02 PM
And if you double click the button, does a new little thing pop up on the bottom of the screen?
Old 01-26-2013, 03:04 PM
Dottore's Avatar
well if I double click the round button, the apps/icons appear at the bottom of the screen.
Old 01-26-2013, 03:09 PM
Go to settings, general, use side switch to lock rotation.
Old 01-26-2013, 03:21 PM
And once that apps/icons section pops up, you should be able to slide it over until you see some settings. I believe one of those settings is to lock the orientation.
Here, instructions complete with pictures.
iPad: Understanding the side switch
Old 01-26-2013, 03:29 PM
That's the problem, his side switch is being used to mute not lock rotation. He just needs to change it. I don't think you can use it to do both symoltaineeyuslee.
Old 01-26-2013, 03:37 PM
Yep, and my link covers that with pics.
Old 01-26-2013, 04:00 PM
So is there the shortcuts posted before with the 2nd Gen? I've been thinking of getting one.
Old 01-26-2013, 04:09 PM
gprsh924's Avatar
Double tap home button. Swipe the right. In the left corner the is a box with a circular arrow. Click it and rotation will lock.
Garrett
Living and Thriving
Old 01-26-2013, 04:27 PM
Dottore's Avatar
Finally got it. You live you learn.
Many thanks for your help guys.
Old 01-26-2013, 05:10 PM
