Look, I know you're giving me a "pro's advice" on how to fix it, but my OCD isn't quite to that level...it's just at a spot that I hit eleventy dozen times per day (when it's squeaking that is) right outside my kitchen. I figured a "quick fix" or "it is what it is" followed by a long miserable existence. Thanks all...(you too G)...you made me laugh too
Being from the south I can appreciate the use of duct tape. I would take it further and use cardboard laid over the sqeaking board and then using duct tape around the edges. When the floor started squeaking in the double wide this fixed it right up.
the unexamined life is not worth living, unless you are reading posts by goofballs-Socrates 88 coupe |
JW Apostate
Find the squeak.
Isolate it. Drill through the surface of the hardwood with a small drill bit as close to the source of the squeak as you can. Find a small headed screw. Drill a shallow hole to accommodate the screw. Run the screw into the hole and into the subfloor. Fill the hole with putty or filler that matches the wood. KT
'74 914-6 2.6 SS #746 '01 Boxster |
good luck. let us know how it goes.
JW Apostate
The ONLY cause of squeaks on a floor is movement of wood on nails...
KT
Thanks KT...I hear ya. I'm absolutely sure there is a nail exactly where the squeak is...I used Senco 2" "L" shaped nails through the HW tongue with a pneumatic Powernailer...them suckers hold! I ain't disagreeing with ya...just can't understand the squeak in this spot. All of the flooring is supertight (no gaps whatsoever) except here...I can see a hairline crack between the micro-bevels. Thanks again...
I'm with Bill
Note to self. For entertainment invite KC to my 75 year old house with the wide pine flooring and watch his head explode as he walks around.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
You might try putting a nice clean piece of 2x4 over the squeek and twapping it with a good sized hammer. Show it some authority.
. Now where's my "floor whacker"...I'm gonna LEARN "old hickory" a lesson for sure...
Just put down carpet!
(another joke)
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
