Air Medal or two
aeronautical Airplane Flap Design
For the Airo Engineers out here....
Hinge points on Flaps Or better - When deployed and in use , Whats better, ?? To have the leading edge of Flap slightly above top of wing contour? (so to run some top air over ?) Or as in most applications they hinge on center and it stays that way through the travel. I notice on jets there is allowances for air to be passed both directions. You cant make a mistake here with your answers...LOL This is for a couple RC airplanes we making .No one is going to be sued LOL Some of the Old HIGH performance Fighters even had flaps under the wing so no top Boundary air was there at all ! So....after much thinking..........i am thinking I do not know much at all
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Kantry Member
Sounds like fun!
I'm NOT an aero engineer and I can't remember the last time I stayed at a Holiday Inn, but looking at your application, it is in reality a low-speed situation. The forces exerted on a surface don't always "scale well" when making models. I'm guessing you need air movement over both surfaces of your flap to gain the full effect. That opinion was worth exactly what you paid for it! ![]() Best Les
Best Les My train of thought has been replaced by a bumper car. |
Well, whatever you choose will depend on complexity to build on an RC.
Commercial airliners use a combo of Fowler and Slotted, which is why you see those huge hinge farings under the wings. |
Air Medal or two
I guess slotted is sort of what i was describing.
Only with the leading edge of flap just a little proud of the top of the wing.........Like everything there is a dozen ways to accomplish task at hand.............. Hoping some one will break dwn pros and cons.
For an RC airplane I would not over think it. I believe what you are trying to describe is a Fowler flap, a fowler flap is doing two things, its changing camber and increasing area. a simple flap would be more than functional for RC planes.
Newton's third law is the real explanation. Bernoulli's principle is the mechanism of how a wing makes lift. What a wing is doing is creating a down ward flow of air, in simple terms a push of air in the opposite direction of the lift. Thats were the term "with enough power you can make a barn door fly; or how airplanes fly upside down, and the reason the split flap works on fighter aircraft. Boundary layer and complex air flow are all considerations in making lift, but if just flying RC aircraft is your interest the more complex anaylsis falls under just good to known. Now if you are more interested a wind tunnel might be in your future. Last edited by romad; 02-04-2013 at 06:02 AM.. |
Air Medal or two
I dont want to reinvent the wheel..........I am sure there is a simple answer.
I realize jets use them at % rates and even act as air brakes LOL Yea enough Power and Snoopys Dog House will fly. Thats not he question Too me it looks like I am getting no where fast here.....
As said, in an RC application you will not know the difference. The slotted set- up will just be a little harder to build. Oh and it might look better.
Air Medal or two
well its going to have a 12 foot wing span..........so dont presume too much
Oh a 12 foot wing that makes all the difference.......the least you will need is a multi element fowler with laminar flow control and winglets, you might have to consider leading edge slats, but generally that's only required with wing spans over 12 foot.
Did you get the memo?
My aero classes were a long time ago, but I believe the primary purpose of the slotted flap is to promote airflow over both the top and bottom surfaces of the flap. The slotted or fowler flaps would be difficult on an R/C, you'll need some sort of flap track and jackscrew type arrangement as the flaps deflect both downwards and move backwards. Pretty complex. I would go with some sort of plain flap for ease of construction, and just focus on getting the area right. If you just want to go low and slow with short takeoff/landing distances, you could also consider adding leading edge slats.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
An other thought is that the wings will be dismounted , so the linkage will have to be simple to disconnect.
Looking out the window on big commercial jets, I see the type called Fowler in the earlier post. Never had heard that name for it. Cheers Richard |
Air Medal or two
I am still wondering through time and space. Reynolds ventries Bernoulli's, boundry Etc ...so i am perplexed........some flaps want to stand the nose on end...others just give a nice soothing Float affect.
Now.to hinge the flaps so their leading edge goes slightly above the main wing trail edge seems ( when deployed ) like there might be a advantage.. Doing two things at once?
Senior Member
Would agree with Matt above but also the jackscrew stuff would weigh more than you would want on an RC airplane. Runway length is usually not an issue so just go with something simple and cheap.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Air Medal or two
Its all simple........just a matter of direction........I HATE going in REVERSE.......a jack screw on small scale would be pretty ez..........and with todays servos...it could just push the flap out
MAGA
RC airplanes typically do not fly like their full scale big brothers. Reynolds numbers and all that... On top of that, your 12' wingspan model if 1/4 scale dimensionally, will not be 1/4 of the weight. The RC will be much lighter I am sure. Example: a 1/4 scale aerobatic RC might weigh 30-40 pounds while it's full scale big brother weighs 1200 pounds. Messing with airfoils is a waste of time typically when it comes to RC. A flat squared off chunk of foam will typically fly about the same as an airfoil shaped piece of foam in the lighter/slower realm of RC aircraft.
As far as flaps go, too much flap (area/deflection or both) and you get a nose down pitching moment. With an RC model, one can simply program in some nose down elevator mix to compensate. That said, the simplest way to add flaps on an RC model is to simply turn the ailerons into flaperons... In other words program the ailerons to droop when throttle is chopped and mix in a touch of nose down elevator as needed.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Air Medal or two
Thanx........and so far i know this and "scale effect" wnig load and all............
BUT Has anyone tried what i am asking ? or does anyone know the result(s) LOL B4 I head off to crazyville
Control Surfaces | 2BFly
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
My t-34, Skylane and Super Cub use these. I have a giant telemaster that I added split flaps on, they also work great. I do not think you want the leading edge of the flap to go above the wing.
Air Medal or two
In My LIL Brain if the leading edge stood proud when deployed..........
Effect - will either act as a speed brake Or or as super flap...the boundary layer is at its limits SO this idea must be wrong OR - will, / would have been applied and in service somewhere in real life...............
What is the motive power? Jet, electric or pistons?
If jet, You could (arguably) try to go for blown flaps?
Thank you for your time, |
