When you are out sitting on the patio looking at the half naked women (yeah right, mountain and canyon views) you will often wonder why people need AC or heat around here.
The electric elements do come on but you could set it to go up 2* and a short time later anoher 2* but we were told it doesn't save enough to make it worthwhile.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Bandwidth AbUser
Jim R. |
It only costs you $32 per month to cool your house in July and August???
It doesn't say where you live but is AC required at all? Geothermal is more efficient but you still have to run a compressor and fans.
Rick 88 Cab |
Our estimated cooling cost for the year in SW WI is $32. The ground water is 48* and make our heating costs rise a bit but the cooling is good. It costs us more than the estimate because we run the house cooler than the estimate. I like cool in the summer. We went a summer without as our old central air unit got hit by lightning and ran the attic fan all summer. That was quite a bit more expensive than the geo unit. June/July/August mostly but May can get warm enough to use it a little.
You do not have permissi
There may be drafts which make a huge difference. My parents also had a furnace which was over-sized. That thing kicked on and off every 10 minutes and the bills were $400+/mo at 60deg. |
I personally set the temp up to 70 at certain times(wake/dinner), then back down to 65-67.
It stays plenty warm for a long time and sweaters are still in fashion. Girlfriend is a lazy smoker, and leaves the window open in the dead of winter ![]() With forced air, the furnace runs until the air temp in that room reaches the set level. What is not factored is the heat-soak of all the surfaces and objects in the house. New electronic "efficiency" thermostats should be programable for a wider swing. That is an easy feature to program in, but I've seen very few with this feature. |
For those of us paying over $100/mo for electricity and $30/mo. for gas, a smart thermostat of any kind is probably going to pay for itself in a few years and return dividends after that. If you're one of those who can remember to turn up/turn down your temps 365, you can save enough for a couple nice dinners out pretty quickly.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Unregistered
IMO simple is good.
A few years ago i finally switched from the dial type to a $16 digital non-programmable, but it ticks me off cause about once a year I gotta put two new AAA batteries in it. |
if your thermostat wire is not 40+ years old, the...the C wire is wired for 18VAC
LockState WiFi Internet 7-Day Programmable Thermostat + Free iPhone App-LS-60i at The Home Depot
Stay away from my Member
I put in two (dual zones) a few months ago - love them! We pay $350 to $1000+ a month for electricity and gas so the ROI should be there. And we do use the iPhone app feature all the time. It's kinda like a TV remote -- until you had one, you never realized how lame it was to not have one.
Chris C. 1973 914 "R" (914-6) | track toy 2009 911 Turbo 6-speed (997.1TT) | street weapon 2021 Tesla Model 3 Performance | daily driver 2001 F150 Supercrew 4x4 | hauler |
I don't understand the reason for adjusting the heat or AC all the time when you are away on that cell phone. is it because there isn't any thing to do.
beancounter
I installed a Nest thermostat in my weekend/county house. The remote capability is very nice to be able to warm the house up a few hours in advance of our arrival. I can also check in on very cold nights to insure that the heating system is maintaining the set temperature. Gives peace of mind that everything is working ok and my pipes aren't going to freeze.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Thermostat is a bandaid. There's also the gas Bloom Box which looks interesting, but not sure if available for non-commercial application. An energy audit is not too expensive, slow-fill foam insulation can be added into walls with minimal intrusion(small hole), and attic ventilation and light roof tiles make a big difference. |
AutoBahned
The contractor that did my energy audit said if there was any insulation at all inside the wall, they could not add more (except by tearing the wall completely open.
Do you have more info on the slow-fill foam insulation? |
Yep. I have three. LOVE them.
Randy, I should have typed slow-rise.
Basically the same open cell stuff but with a slower reaction time to not push out the drywall. They drill a series of small holes (1/4-1/2" I think) and start at the bottom. Two chemicals start as liquid, and turn into foam. All excess comes out the holes. AFAIK, was told it can be used with existing batt insulation. The foam just seals any gaps with the fiberglass settling. I just looked at a finished basement bathroom (cold Mich) where paint was sagging off the drywall. There had been a fixed slow shower leak, but I suspected there was also an air gap at the top, and cold air was creating condensation inside that wall. The wall with sagging paint felt much colder to the touch than the other without problems. |
AutoBahned
thx, I will look into that
