Targa, Panamera Turbo
M.D. Holloway's Avatar
The Polonnaruwa Meteorite: Oxygen isotope, Crystalline and Biological Composition
Astrobiologists Find Ancient Fossils in Fireball Fragments - MIT Technology Review
On 29 December 2012, a fireball lit up the early evening skies over the Sri Lankan province of Polonnaruwa. Hot, sparkling fragments of the fireball rained down across the countryside and witnesses reported the strong odour of tar or asphalt.
Over the next few days, the local police gathered numerous examples of these stones and sent them to the Sri Lankan Medical Research Institute of the Ministry of Health in Colombo. After noticing curious features inside these stones, officials forwarded the samples to a team of astrobiologists at Cardiff University in the UK for further analysis.
The results of these tests, which the Cardiff team reveal today, are extraordinary. They say the stones contain fossilised biological structures fused into the rock matrix and that their tests clearly rule out the possibility of terrestrial contamination.
In total, Jamie Wallis at Cardiff University and a few buddies received 628 stone fragments collected from rice fields in the region. However, they were able to clearly identify only three as possible meteorites.
The general properties of these three stones immediately mark them out as unusual. One stone, for example, had a density of less than 1 gram per cubic centimetre, less than all known carbonaceous meteorites. It had a partially fused crust, good evidence of atmospheric heating, a carbon content of up to 4 per cent and contained an abundance of organic compounds with a high molecular weight, which is not unknown in meteorites. On this evidence, Wallis and co think the fireball was probably a small comet.
The most startling claims, however, are based on electron microscope images of structures within the stones (see above). Wallis and co. say that one image shows a complex, thick-walled, carbon-rich microfossil about 100 micrometres across that bares similarities with a group of largely extinct marine dinoflagellate algae.
They say another image shows well-preserved flagella that are 2 micrometres in diameter and 100 micrometres long. By terrestrial standards, that’s extremely long and thin, which Wallis and co. interpret as evidence of formation in a low-gravity, low-pressure environment.
Wallis and co. also measured the abundance of various elements in the samples to determine their origin. They say that low levels of nitrogen in particular rule out the possibility of contamination by modern organisms which would have a much higher nitrogen content. The fact that these samples are also buried within the rock matrix is further evidence, they say.
Wallis and co. are convinced that the lines of evidence they have gathered are powerful and persuasive. "This provides clear and convincing evidence that these obviously ancient remains of extinct marine algae found embedded in the Polonnaruwa meteorite are indigenous to the stones and not the result of post-arrival microbial contaminants," they conclude.
There's no question that a claim of this kind is likely to generate controversy. Critics have already pointed out that the stones could have been formed by lightning strikes on Earth although Wallis and co. counter by saying there was no evidence of lightning at the time of the fireball and that in any case, the stones do not bear the usual characteristics of this kind of strike. What's more, the temperatures generated by lightning would have destroyed any biological content.
Nevertheless, extraordinary claims require extraordinary evidence and Wallis and co. will need to make their samples and evidence available to the scientific community for further study before the claims will be taken seriously.
If the paper is taken at face value, one obvious question that arises is where these samples came from. Wallis and c.o have their own ideas: "The presence of fossilized biological structures provides compelling evidence in support of the theory of cometary panspermia first proposed over thirty years ago," they say.
This is an idea put forward by Fred Hoyle and Chandra Wickramasinghe, the latter being a member of the team who has carried out this analysis.
There are other explanations, of course. One is that the fireball was of terrestrial origin, a remnant of one of the many asteroid impacts in Earth's history that that have ejected billions of tonnes of rock and water into space, presumably with biological material inside. Another is that the structures are not biological and have a different explanation.
Either way, considerably more work will have to be done before the claims from this team can be broadly accepted. Exciting times ahead!
Ref: arxiv.org/abs/1303.1845: The Polonnaruwa Meteorite: Oxygen isotope, Crystalline and Biological Composition
Interesting stuff...
Michael D. Holloway
https://5thorderindustry.com/
Old 03-17-2013, 04:51 PM
mikesride's Avatar
whoa!!!! Way cool!!!
I've driven alot of crap to get here man!
Old 03-17-2013, 04:55 PM
AutoBahned
RWebb's Avatar
we should go to Mars and drill into some rocks
Old 03-17-2013, 05:55 PM
And we should explore our world to the core (or close), there is more to learn here and it may just give us insight into the universe as well...
Michael D. Holloway
Old 03-18-2013, 10:48 AM
Rover finds grey rock beneath Red Planet's surface
Read more: Rover finds grey rock beneath Red Planet's surface
So much for Mars being "The Red Planet".
NASA said that its Curiosity rover has scooped up a sample from the interior of a Martian rock and found that the powdery soil just beneath the planet's rust-coloured exterior is actually a light grey colour.
"Something that the science team is really excited about, is the fact that the tailings from our drill operation aren't the typical rusty orange-red that we associate with just about everything on Mars," said Joel Hurowitz, sampling system scientist for Curiosity.
"When things turn orange, it's because there's a rusting process of some kind going on that oxidises the iron in the rock," he said during a press conference at NASA's Jet Propulsion Laboratory (JPL) in Pasadena, California.
Seaweed Aliens Invade Earth Inside Sri Lankan Meteorite, Scientist Claims
http://www.ibtimes.co.uk/articles/427033/20130123/aliens-exist-seaweed-algae-inside-meteorite-fossil.htm
"Since this meteorite is considered to be an extinct cometary fragment, the idea of microbial life carried within comets and the theory of cometary panspermia is thus vindicated.
I think finding fossils and actual life are two different things, but it is very interesting.
http://m.technologyreview.com/view/512381/astrobiologists-find-ancient-fossils-in-fireball-fragments/
Old 03-18-2013, 11:18 AM
canna change law physics
red-beard's Avatar
There was a show recently on one of the History Channels which posited that the periodic new viruses were actually DNA dropping into the earth's atmosphere. The Spanish flu is supposed to have been too wide spread and spread too quickly for normal terrestial transmission.
James
Red-beard for President, 2020
Old 03-18-2013, 11:26 AM
Meteorite life: Claims of fossils in a meteorite are still wrong.
Maybe not?
Brent
Old 03-18-2013, 12:24 PM
sjf911's Avatar
Extraordinary claims require extraordinary evidence. So far, there is compelling evidence that the "diatoms" published in the Journal of Cosmology article, in fact, represent fresh water contamination as they display numerous different species of diatoms already found on earth. Also, there is no chain of possession documentation to verify these samples as truly from a recent event.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 03-18-2013, 12:37 PM
Banned
could be life but ''JUST'' our own stuff blasted up and out by a long ago strike
like the dino killer impact
Old 03-18-2013, 12:43 PM
