"O"man(are we in trouble)
What caused limo fire?
What the hell happened here that could cause this kind of rapid spreading fire? What is back there that can do this, fuel leak, electrical short?
Driver, passenger differ on fatal limo inferno - CBS News |
Can of gas stored in the trunk that tipped over maybe??
12' GT3 18’ 991S |
(the shotguns)
awful story. lots of electrical connections in a limo that might not be OE quality controlled.
can of gas wouldn't need to spill, just release fumes that aren't vented to outside the car. I would think we'd have heard about a gas smell in the car by now though.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
This is a horrible story, certainly. I am also very interested to know not only what caused the fire but why it spread so rapidly. I'd discount the gas can idea as if fumes were present, there would be an explosion rather than a fire. I'm thinking along the lines of electrical connections--heavy duty pre-amps for example--that started the fire, began burning the interior components/aftermarket insulation, then rapid acceleration when the door was opened and outside air fed the fire. Regardless, what a tragedy.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Platinum Member
Sad tragedy.
Car fires start and spread fast. Seems to me I've seen more roadside fires since alcohol in gas. It wouldn't surprise me if it deteriorates rubber fuel lines faster. |
D idn't E arn I t
Bet it had to do with the electric fuel pump- probably a ruptured line + wiring. Limos aren't exactly what one would call "quality" work..
rjp
AOC/Hogg 2028 |
If I understand the story correctly, there were at least two nurses in the group. Nurses are trained to act quickly and decisively, so this fire must have been very very fast.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Absolute tragedy!
And, I have to admit, Randy P, your avatar freaks me out a little. Just sayin'...
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
I wonder if it was the ethanol. It was a 1999 town car. From what I've read before, cars weren't designed to run ethanol until 2006. The hoses and fuel pump seals could have rotted away. Thanks for nothing EPA morons.
1972 Dodge Challenger 2011 Raptor 2013 Road King 110th Anniversary 2014 Corvette Z51 stingray Single after 27 years married. |
Detached Member
Bacardi 151?
Hugh |
Parking brake left set? Heated up and started a fuel line fire?
'84 Carrera Cabriolet |
With LOTS of pushing from the corn lobby. Many morons involved. Many $$$ to be made.
Archer Daniels Midland: A Case Study In Corporate Welfare
Unregistered
Bingo. what's typically in the back of a limo that is rented out for a bachelorette party? Drunk women and alcohol. Not the crap in the fuel tank, the crap in the bottles.
Pure speculation, but a likely scenario would involve spilled spirits and an ignition source. |
Now in 993 land ...
My bet also is alcohol. Limo rides often come with a large bottle of vodka etc. included in the deal.
It has to be a liquid fuel of some sort. Gasoline is next on the list. I can't see an electrical fire getting out of control that quickly. Talk about bad luck. It couldn't even be on the way back from the party ... G |
D idn't E arn I t
Badge of honor
AOC/Hogg 2028 |
Just thinking out loud
Speculation is that it took 50 seconds to flare up? Knowing that limos have separate ac systems for the rear, a wild guess could be that the rear condenser fan malfunctioned and generated enough resistance and heat to melt the wiring, which flamed up with the aid of an oily undercarriage, melting the fuel line.
Just a guess.
83 944 91 FJ80 84 Ram Charger (now gone) |
The photo of the car on fire still moving looks like a gas-fed fire. Huge conflagration.
AutoBahned
I'm still wondering about the rear doors.
