AutoBahned
what caused this crazed paint
at least that is what I am calling these cracks - let me know if there is a more technical term
the front of this VW Vanagon was repainted in April 2011 - this spring I see this: ![]() |
Slackerous Maximus
Poor surface preparation.
2022 Royal Enfield Interceptor. 2012 Harley Davidson Road King 2014 Triumph Bonneville T100. 2014 Cayman S, PDK. Mercedes E350 family truckster. |
Yup.... They didn't get something clean and the paint is letting go. I'd be making the body shop fix that...
Are those cracks in the paint? Then I'd call it crazing. But to me it looks raised such as a reactive chemical get on there.
Senior Advisor
if aluminum it's called filiform corrosion caused by not properly prepping for paint, greater with polyurethane paint.
08 Cayenne Turbo |
AutoBahned
no, that is a steel panel
I do not trust this body shop to fix it as they screwed up everything else too. I'll either take it somewhere else and eat the cost, or try to get them to fix it. |
I had exactly that happen on the bonnet of a 2 year old metallic black car. It was bird droppings with little berries in it that contracted as it dried and must have pulled the paint in. The heat from the engine and the absorbed solar heat (from being black) meant it dried very quickly. By the time I got home and hosed it off maybe 8 hours later it had done the damage. It left exactly the pattern you have there.
AutoBahned
no bird droppings in this instance
Run smooth, run fast
Peter Egan, about 2/3rds of the way through my favorite Side Glances sometime in the '80's... I cut it out and saved it... don't think it's in any of his books... don't know why because the whole thing is hilarious:
LESSONS FROM THE SHADE TREE A brief look at the backyard restoration of old British sports cars If you fill a fender dent with Bondo or Black Magic in the middle of February when the temperature in your garage is right around zero, the body putty will eventually cure to a consistency resembling chilled Camembert cheese. Months later when you park the car in the hot sun the filler will expand slightly, creating a crack in the paint that looks something like a map of Australia.
- John "We had a band powerful enough to turn goat piss into gasoline." |
I would venture to say continued curing of the filler/substrate used in the repair. Some of these material will continue to cure months to years after application.
You do not have permissi
Could it be due to the wrong activator used with the base or clear?
I think there are differnet activator heat ranges used for different tempertures, which ensures the chemicals stabilize and harden in a certain timeframe. One layer might have taken a year to cure. My other guess would be the clear was sprayed on before the base coat was fully dry. When the clear contracts when finally curing(all solvents evaporated), I'd guess it could pull sideways on the thin layer of basecoat. That basecoat doesn't look too thick... Last edited by john70t; 05-20-2013 at 10:05 AM.. |
Is there any possibility that the car was hit with an egg. or eggs thrown by some juvenile delinquents ? I believe that eggs can do this to paint.
Air Medal or two
Do all you guys that chime in here even have paint experience ? LOL
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
AutoBahned
no chance of an egg hit - exposed to rain in winter is all
Thread Tools | |
Rate This Thread | |
