Max Sluiter
Edit: I assumed that kiwiokie was replying to the comment about F1 engines.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance Last edited by Flieger; 05-31-2013 at 01:52 AM.. |
Max Sluiter
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Cars & Coffee Killer
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Still Doin Time
Actually, this idea is not new. Smokey Yunick (I think) in the early 60's with a small block chevy tried electric solonoids with very mild springs on each valve actuated by a crude 'computer'. I believe they used a punch-card setup to control the 'on' time. The primary reason this was tested was the lack of good valve train hardware and materials so a really agressive cam lobe profile could be utilized. IE: Instant max lift / instant close.
Some of the more forward thinking people in racing engine development then started to hit a wall with cam lobe / lifter angles. There is a lag moment in time where the valve is not fully open or not fully closed resulting in loss of static compression, combustion pressure marginal airflow through the ports. With a solid base lifter there is only so much angle in relation to the lobe ramp that can be run W/O mechanical binding or very rapid wear. Ideally you want to 'yank' the valve max opan at the last micro second then slam it closed. You can make a lot power all over the RPM range with little downside. But in reality you can only accelerate the valve train so much and then de-accelerate so much to achieve that before something breaks. The 'camless' SBC idea was soon abandoned. They had a runing prototype on the dyno but technology, solonoids and controlers had not progressed far enough to be practical in a racing engine. The next step was roller lifters. Some of you may be suprised that roller lifter technology had been developed by ........get this....................Harley-Davidson in the 1920's on their board track racing engines. Chet Herbert (of the cam company - Doug Herberts father) used to race Harley's at El Mirage and then Bonneville. He lost the use of his legs after a bad racing accident an turned to cars and engine building to continue his passion. You can credit Harley-Davidson with the original design and use for the roller lifter in combustion engines but it was Chet Herbert who adapted them to automotive engines to achieve quicker valve openings and closings so much more lift and duration could be ground into the profile W/O sacrifcing so much low-end power. With a rollerized valvetrain you could now extract a lot more usable power per cubic inch. Also there is huge parasitic HP loss in spinning all that ***** around. Next to piston rings and skirts draging up and down in the cylinder bore, a racing engine's valvetrain requires a lot of power to spin and actuate all that stuff @7500RPM. It will very interesting to see where the technology goes concerning this
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
5String
I think the deal with F1 engines is that they do indeed have cams to open the valves, but compressed air stored in an onboard tank is used to slam the valves closed.
5String Tell not a soul that you have seen me; breathe not a word of what I say.... The Northwest Files |
My daughter has a camshaftless engine as well. Not a rotary either. Fouls plugs if she doesn't ride it hard though.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. Last edited by flipper35; 05-31-2013 at 01:11 PM.. |
I sit corrected
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html |
