This Copy Of Windows Is Not Genuine
I bought my daughter a used Thinkpad X series Tablet (a corporate return, I think), maxed the RAM and installed a SSD, and she's been happy - until she started getting repeated messages saying "this copy of Windows is not genuine." We run AVG so I'm assuming it is a genuine Windows message about Windows not being genuine, if you get my drift. Any solution beyond buying a Win 7 disc and installing it? What's the cheapest version of Win 7 that isn't crippled and has the Tablet features?
Flip the laptop over and look at product key stamped on the sticker. Is it an OEM key? If so, you need an OEM installation disc of Windows 7. Follow the link below...
Legal Download from DigitalRiver: Windows 7 SP1, 13 languages Edit: Before you do all of that, try going to properties and checking the windows activation pane. Hit change product key and try typing in the serial on the back of the computer. |
It probably needs to be reactivated since the drive change.
Does it have a key on the bottom? You could either try changing the key to something bogus, then back and reactivating, or just calling MS and telling them what happened and they'll set it to be able to activate if it's a valid key.
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
Duh! Thank you both for that.
Or you could ditch windows... I've heard good things about thinkpads and Linux
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
canna change law physics
Win 7 Home. You can get it from New Egg or Amazon. I think all versions of Win 7 have the tablet features. You may have to activate them. Just like you can activate the voice command features.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Super Moderator
?..as above, if you change drives, sometimes you have to reactivate windows....
Tried the key on the Windows label on the underside of the laptop, response is that it is invalid.
Windows Activation offers to sell me a genuine product key with backup media mailed. That is for Win 7 Pro SP 1 which is on the laptop now, for $149. Windows Activation says well, we can sell you Win 7 Home for $100 but a full re-install will be required. Cripes, it is worth $49 to me not to have to track down all the ThinkVantage software and utilities, drivers, applications and reinstall everything. So, guess MSFT will make another $149 off me.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Platinum Member
Pop the old drive in, and see if there is an option to make backup cds?
Did you buy from a company or private? any chance of getting cds? |
I run into this all the time when making changes to virtual machines, ie increasing vRAM or vCPU. I've even tripped it by increasing the vdisk size or moving the VM to a different subnet. Sometimes it trips for no apparent reason whatsoever.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Banned
they should not double charge you think pad is ibm/lenovo they should be able to send you w7 disks may hit you for shipping/handling but far less then 150 I would try lenovo first but do NOT cave to ms they should reactivate your box free try to go up the food chain to a manager btw w7 will run fine it just gets the not valid messages there is no loss of function I have a box that has been doing that for a few years |
One problem with NOT getting the license is that you can't install updates.
If it was triggered by a hard-disk change, you should be able to call Micro-squish and get a new activation code.
Navin Johnson
I went through this when power supply failure fried the MB... I was able to use my old key to get a new key for a totally rebuilt pc..... new MB new HS(s) new mem, new vid card... etc...
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
You don't have to spend $150 for a new license. Either call them and explain your situation or just follow the steps below.
1: Download the version of Windows that you have the license key for (check my link). If you have an OEM key, make sure you get the OEM copy. 2: Burn the ISO 3: Backup Data / Reinstall Windows |
You do not have permissi
If 'upgrading' to Windows7, it might be worth it. Restoring OEM software functionality shouldn't cost anything, or minimal. If pushed into Windows8, I'd consider other options... |
Win7 Loader by DAZ but you didn't hear it from me.
This will eliminate the message and allow access to updates. |
Senior Member
Just went through this with a new installation of W7. Had to call them and go through the automated activation drill. That said it worked fine and now not getting that damm error msg.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
bunch of random cars and bikes. |
